Aller au contenu principal
Logitech K480 Metal Plate Replacement
Ce dont vous avez besoin
  1. Logitech K480 Metal Plate Replacement, Back Cover: étape 1, image 1 de 1
    • Flip the keyboard over.
  2. Logitech K480 Metal Plate Replacement: étape 2, image 1 de 3 Logitech K480 Metal Plate Replacement: étape 2, image 2 de 3 Logitech K480 Metal Plate Replacement: étape 2, image 3 de 3
    • Remove the four rubber feet with a spudger.
  3. Logitech K480 Metal Plate Replacement: étape 3, image 1 de 3 Logitech K480 Metal Plate Replacement: étape 3, image 2 de 3 Logitech K480 Metal Plate Replacement: étape 3, image 3 de 3
    • Slide open battery panel.
    • Remove the batteries.
  4. Logitech K480 Metal Plate Replacement: étape 4, image 1 de 2 Logitech K480 Metal Plate Replacement: étape 4, image 2 de 2
    • Remove the three 4 mm screws under the rubber feet using a Phillips #0 screwdriver.
  5. Logitech K480 Metal Plate Replacement: étape 5, image 1 de 2 Logitech K480 Metal Plate Replacement: étape 5, image 2 de 2
    • Remove the two 4 mm screws from beneath the battery cover using a Phillips #0 screwdriver.
  6. Logitech K480 Metal Plate Replacement: étape 6, image 1 de 3 Logitech K480 Metal Plate Replacement: étape 6, image 2 de 3 Logitech K480 Metal Plate Replacement: étape 6, image 3 de 3
    • Starting by the dial, slide the spudger between the front and back panels until it lifts and snaps.
    • Slide a blue pick in to keep the pieces apart while you work on other areas.
    • Continue prying along the edges until you have enough opened that you can pull both pieces apart gently with your hands.
    • The loud snaps are the clips that hold the pieces together. They're not breaking and you do not need to be alarmed.
  7. Logitech K480 Metal Plate Replacement, Metal Plate: étape 7, image 1 de 3 Logitech K480 Metal Plate Replacement, Metal Plate: étape 7, image 2 de 3 Logitech K480 Metal Plate Replacement, Metal Plate: étape 7, image 3 de 3
    • Remove the eight 3 mm screws using a Phillips #00 screwdriver
    • Remove the five 2 mm silver screws from the metal plate using a Phillips #00 screwdriver.
    • Remove the single 4 mm black screw by the motherboard using a Phillips #00 screwdriver.
  8. Logitech K480 Metal Plate Replacement: étape 8, image 1 de 2 Logitech K480 Metal Plate Replacement: étape 8, image 2 de 2
    • Lift up and remove the metal plate.
Kristen Gismondi
Membre depuis le 11/12/14
92 036 Réputation
241 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 450 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 14
30 derniers jours : 17
Total : 41
