Introduction
Follow this guide to remove and replace the battery in a Logitech MX Keys wireless keyboard.
Note: If your battery looks puffy or swollen, take extra precautions.
Pièces
Aucune pièce spécifiée.
Flip the keyboard over and lay it top-side down onto a clean work surface.
Heat an iOpener and lay it on the left plastic foot for about two minutes.
Insert the pointed end of a spudger under the edge of the foot.
Push the spudger underneath the foot and pry up to release its adhesive.
Once you can grip the foot with your fingers, peel it up and away from the keyboard to remove it.
Repeat steps 2–3 for the remaining two feet.
Use the pointed end of a spudger to poke through the film underneath each foot to access the screw underneath.
Use a spudger to gently "walk" the battery cable out of its connector.
Remove the three power cables from their channel in the keyboard.
Insert the flat end of a spudger underneath the short end of the battery opposite the cables.
Push the spudger underneath the battery, separating it from the adhesive holding it to the keyboard.
Remove the battery.
Remove any leftover adhesive from the battery well.
Apply double sided tape or pre-cut adhesive to secure the new battery.
2 autres ont terminé cette réparation.
