Introduction
Use this guide to replace a worn or unresponsive clicker switch in a Logitech MX Master 3 or MX Master 3S mouse. The clicker switch is a small mechanical component beneath the primary mouse buttons, and it's one of the first parts to wear out with heavy use.
Common symptoms of a failing clicker include: double-clicking when you only press once, clicks that don't register at all, a mushy or inconsistent feel when pressing the button, or a left/right click that feels noticeably different from when the mouse was new. If you're experiencing any of these, a clicker replacement is likely the fix.
Before you begin, be aware of the following hazards:
- Static discharge — The MX Master 3/3S contains sensitive electronics. Work on a non-carpeted surface and consider using an anti-static wrist strap to avoid damaging components.
- Heat — Since the replacement involves soldering, use care around the PCB. Excess heat can lift pads or damage nearby components.
- Small parts — The mouse contains tiny screws and clips that are easy to lose. Work over a tray or mat and keep a container nearby for hardware.
Tools and skills you'll need: This repair requires basic soldering skills — you'll need to desolder the old switch and solder in the replacement. If you've never soldered before, practice on scrap electronics first.
Ce dont vous avez besoin
Insert a plastic opening tool into the seam between the top shell and the bottom case along the side of the mouse.
Once all clips are released, carefully lift the top shell, but do not remove it completely yet—internal cables are still attached.
Support the top shell with one hand so the cable is not strained.
Your Logitech MX Master 3S is now back in action with a new clicker/switch. The desoldering and resoldering process may take some practice, but the result is a fully restored, responsive mouse.
Before reassembling, test the new switch to ensure proper click registration and smooth operation. If everything feels right, reattach the mouse feet pads and screw everything back together.
Enjoy your refreshed mouse!
3 commentaires de tutoriel
Thank you for the guide. How is the click profile of the switches compared to the original?
@carlosunch It seems to be close to the original. The replacement switches were meant to be more silent as not to make much noise but it feels very close to the original in my opinion.
