Aller au contenu principal
Logitech MX Vertical Feet Replacement
Ce dont vous avez besoin
  1. Logitech MX Vertical Feet Replacement, Turn off the mouse: étape 1, image 1 de 1
    • Before you begin, flip the mouse's power switch into the OFF position.
  2. Logitech MX Vertical Feet Replacement, Lay the mouse buttons-side down: étape 2, image 1 de 1
    • The mouse's unique shape prevents it from laying flat. If you need to, lay it button-side down onto a soft towel to prevent wobble.
  3. Logitech MX Vertical Feet Replacement, Heat the feet adhesive: étape 3, image 1 de 2 Logitech MX Vertical Feet Replacement, Heat the feet adhesive: étape 3, image 2 de 2
    • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to the feet on the mouse's underside for about two minutes.
    • Alternatively, a hair dryer or a heat gun may also be used, but be careful not to overheat the mouse.
  4. Logitech MX Vertical Feet Replacement, Remove the mouse feet: étape 4, image 1 de 3 Logitech MX Vertical Feet Replacement, Remove the mouse feet: étape 4, image 2 de 3 Logitech MX Vertical Feet Replacement, Remove the mouse feet: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Insert one arm of a pair of sharp tweezers underneath the end of one foot.
    • Grip the foot and begin to peel it away from the bottom of the mouse.
    • Peel slowly, making sure the foot and its adhesive are removed in one piece.
    • The foot should come away from the mouse without the need for much force. If it feels stuck, apply more heat and try again.
  5. Logitech MX Vertical Feet Replacement: étape 5, image 1 de 3 Logitech MX Vertical Feet Replacement: étape 5, image 2 de 3 Logitech MX Vertical Feet Replacement: étape 5, image 3 de 3
    • Use a pair of tweezers to peel the foot away from the mouse to completely remove it.
    • Place the foot adhesive-side up on a clean surface.
  6. Logitech MX Vertical Feet Replacement: étape 6, image 1 de 3 Logitech MX Vertical Feet Replacement: étape 6, image 2 de 3 Logitech MX Vertical Feet Replacement: étape 6, image 3 de 3
    • Insert a tweezer arm underneath the end of the second foot.
    • Peel the foot away from the mouse to completely remove it.
    • The foot should come away from the mouse without much force. If it feels stuck, apply more heat and try again.
    • During reassembly, remove any leftover adhesive before installing new feet.
5 autres ont terminé cette réparation.
Carsten Frauenheim
Membre depuis le 03/10/20
135 539 Réputation
371 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 418 tutoriels rédigés
2 commentaires
Do you have to heat it to re-apply the feet?
Jimmy - Réponse
Beste,
Weet je toevallig, waar ik de nieuwe voetjes van Logitech MX Vertical kan kopen?
Groeten,
peter smith
peter - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 33
30 derniers jours : 86
Total : 3,740
