Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Logitech UE Hyperboom DC Power Socket Replacement
Ce dont vous avez besoin
  1. Logitech UE Hyperboom DC Power Socket Replacement, Handle: étape 1, image 1 de 2 Logitech UE Hyperboom DC Power Socket Replacement, Handle: étape 1, image 2 de 2
    • Unscrew the two black flat-top screws that attach the handle to the speaker with your hands.
    • You may need pliers to grip the screws.
    Demander à FixBot
    Ajouter un commentaire
  2. Logitech UE Hyperboom DC Power Socket Replacement, Bottom Panel: étape 2, image 1 de 2 Logitech UE Hyperboom DC Power Socket Replacement, Bottom Panel: étape 2, image 2 de 2
    • Use the Jimmy to pry off the four rubber feet on the bottom of the speaker.
    Demander à FixBot
  3. Logitech UE Hyperboom DC Power Socket Replacement: étape 3, image 1 de 3 Logitech UE Hyperboom DC Power Socket Replacement: étape 3, image 2 de 3 Logitech UE Hyperboom DC Power Socket Replacement: étape 3, image 3 de 3
    • Use a Phillips #0 screwdriver to remove all twelve 11.7mm screws from the bottom panel of the speaker.
    • Pull the panel off to access the internal components.
    Demander à FixBot
  4. Logitech UE Hyperboom DC Power Socket Replacement, DC Power Socket: étape 4, image 1 de 3 Logitech UE Hyperboom DC Power Socket Replacement, DC Power Socket: étape 4, image 2 de 3 Logitech UE Hyperboom DC Power Socket Replacement, DC Power Socket: étape 4, image 3 de 3
    • Unscrew the top 11.7m screw on the DC Power Socket panel using the Phillips #0 screwdriver.
    • Use the Jimmy to pry the panel away from the speaker, then disconnect the power cables from the daughterboard.
    Demander à FixBot
  5. Logitech UE Hyperboom DC Power Socket Replacement: étape 5, image 1 de 2 Logitech UE Hyperboom DC Power Socket Replacement: étape 5, image 2 de 2
    • Remove the four 7.9mm screws from the daughterboard with the Phillips #0 screwdriver.
    • Pull the circuit board away from the panel.
    Demander à FixBot
Ethan Abbott
Membre depuis le 03/10/26
859 Réputation
8 tutoriels rédigés
Équipe
1 commentaire de tutoriel
G'day I've got the 2024 version that has a broken charging port and can't find a PCB replacement anywhere I'm in New Zealand probably why but do you guys reckon I could just swap it out with the older version of the charging board since there available.
Ethan Donaldson - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 14
30 derniers jours : 47
Total : 154
