Aller au contenu principal
Pour réparer ensemble - Je crée un compte
MSI GE62 6QF Apache Pro RAM Replacement
Ce dont vous avez besoin
  1. MSI GE62 6QF Apache Pro  RAM Replacement, Optical Drive: étape 1, image 1 de 1
    • Use a Phillips screwdriver to remove the 5mm screw securing the optical drive to the bottom case.
    Demander à FixBot
    Ajouter un commentaire
  2. MSI GE62 6QF Apache Pro  RAM Replacement: étape 2, image 1 de 1
    • Slide Optical Drive out of the computer.
    Demander à FixBot
  3. MSI GE62 6QF Apache Pro  RAM Replacement, Bottom Case: étape 3, image 1 de 1
    • Use a Phillips screwdriver to remove the fourteen 5mm screws on the back of the laptop.
    • One of these screws is hidden under a sticker.
    Demander à FixBot
  4. MSI GE62 6QF Apache Pro  RAM Replacement: étape 4, image 1 de 3 MSI GE62 6QF Apache Pro  RAM Replacement: étape 4, image 2 de 3 MSI GE62 6QF Apache Pro  RAM Replacement: étape 4, image 3 de 3
    • Remove the three PH #0 2mm screws that were hidden underneath the optical drive.
    Demander à FixBot
  5. MSI GE62 6QF Apache Pro  RAM Replacement: étape 5, image 1 de 2 MSI GE62 6QF Apache Pro  RAM Replacement: étape 5, image 2 de 2
    • Use an opening tool to run along the seam of the case where the upper and bottom case meet.
    • Pry the bottom case and remove from the upper part.
    Demander à FixBot
  6. MSI GE62 6QF Apache Pro  RAM Replacement, Battery: étape 6, image 1 de 3 MSI GE62 6QF Apache Pro  RAM Replacement, Battery: étape 6, image 2 de 3 MSI GE62 6QF Apache Pro  RAM Replacement, Battery: étape 6, image 3 de 3
    • Remove the single PH #0 5mm screw holding the battery pack in place.
    • Remove the battery by sliding it away from the computer.
    Demander à FixBot
  7. MSI GE62 6QF Apache Pro  RAM Replacement, RAM: étape 7, image 1 de 2 MSI GE62 6QF Apache Pro  RAM Replacement, RAM: étape 7, image 2 de 2
    • Pull the metal tabs that hold the RAM in place away horizontally from the RAM stick, and slide the RAM out of the socket.
    • Repeat the same steps for the other RAM stick.
    Demander à FixBot
Juan Erquiaga
Membre depuis le 09/26/17
107 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S2-G3, Passmore Fall 2017 Membre de l'équipe USF Tampa, Team S2-G3, Passmore Fall 2017
USFT-PASSMORE-F17S2G3
3 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 8
30 derniers jours : 30
Total : 2,488
