Introduction
If your device isn’t registering or recognizing a USB connected device, you may need to replace the USB port. Follow these instructions to replace the USB port in the MSI GP62MVR 6RF Leopard Pro laptop.
Ce dont vous avez besoin
Place the laptop upside down.
Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
Using a Phillips #0 Screwdriver, remove the single 5.5 mm screw fastening the battery to the body of the computer.
Remove the battery from the device.
Reorient the computer, if necessary, with a 180 degree turn so that the speakers face you.
Using a Phillips #0 screwdriver, remove twelve 4.5 mm screws fastening the heat sink to the motherboard.
Unclip the red, blue, and black intertwined wire gently from the left side of the motherboard.
Detach the black and red wire from the right side of the motherboard, as well as peel away the black tape connecting the large black wire to the motherboard.
At the middle-top right of the motherboard, there is a ribbon wire connection to the USB port.
Detach the white and blue motherboard ribbon from the USB port.
