Aller au contenu principal
Pour réparer ensemble - Je crée un compte
MSI GS70 Solid State Drive Replacement
Ce dont vous avez besoin
  1. MSI GS70 Solid State Drive Replacement, Solid State Drive: étape 1, image 1 de 2 MSI GS70 Solid State Drive Replacement, Solid State Drive: étape 1, image 2 de 2
    • Locate and remove all screws securing the back plate. Place the screws on the magnetic mat.
    • Locate one of the openings on the side and gently pull the back plate up to remove it.
    Demander à FixBot
    Ajouter un commentaire
  2. MSI GS70 Solid State Drive Replacement: étape 2, image 1 de 1
    • Locate the solid state drive. It is initially obscured by a connector, its okay to push away the connector to access the solid state drive.
    Demander à FixBot
  3. MSI GS70 Solid State Drive Replacement: étape 3, image 1 de 1
    • Remove the screw holding the solid state drive. Place the screw on the magnetic mat
    Demander à FixBot
  4. MSI GS70 Solid State Drive Replacement: étape 4, image 1 de 1
    • Gently remove the solid state drive.
    Demander à FixBot
  5. MSI GS70 Solid State Drive Replacement: étape 5, image 1 de 1
    • There are different form factors for solid state drives and so you have to pick the appropriate one.
    • The MSI GS70 will only accept 50mm solid state drives so buy accordingly.
    Demander à FixBot
  6. MSI GS70 Solid State Drive Replacement: étape 6, image 1 de 1
    • There is a second solid state drive right next to the first one if you want to add another solid state drive.
    Demander à FixBot
Once you have secured the solid state drive, push and screw in the back plate.
2 autres ont terminé cette réparation.
Gene Abuan
Membre depuis le 04/18/18
310 Réputation
2 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 41
Total : 3,262
