Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Mac Pro First Generation GPU Replacement
    1. Mac Pro First Generation GPU Replacement, Case Panel: étape 1, image 1 de 1
      • Lift the lever to unlock the case.
      Demander à FixBot
      Ajouter un commentaire
    2. Mac Pro First Generation GPU Replacement: étape 2, image 1 de 1
      Outil utilisé dans cette étape :
      Anti-Static Wrist Strap
      $7.95
      • Remove the side panel of the Mac Pro.
      • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
      Demander à FixBot
    1. Mac Pro First Generation GPU Replacement, GPU (Graphics Card): étape 3, image 1 de 1
      • Locate the graphics card in the open panel side of your Mac Pro.
      Demander à FixBot
    2. Mac Pro First Generation GPU Replacement: étape 4, image 1 de 3 Mac Pro First Generation GPU Replacement: étape 4, image 2 de 3 Mac Pro First Generation GPU Replacement: étape 4, image 3 de 3
      • Unscrew the two thumb screws by twisting counterclockwise using your fingers until the slide lock is released.
      • Remove the slide lock.
      Demander à FixBot
    3. Mac Pro First Generation GPU Replacement: étape 5, image 1 de 3 Mac Pro First Generation GPU Replacement: étape 5, image 2 de 3 Mac Pro First Generation GPU Replacement: étape 5, image 3 de 3
      • Push up on the clip directly behind the graphics card to release it from its slot.
      • Slide the graphics card out of the slot using both hands by firmly holding the corners of the top of the card as shown.
      • Handle the card only by its edges. Don't touch any exposed components or connectors.
      Demander à FixBot
23 autres ont terminé cette réparation.
Andrew Kim
Membre depuis le 10/12/14
1 263 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 6-24, Maness Fall 2014 Membre de l'équipe Cal Poly, Team 6-24, Maness Fall 2014
CPSU-MANESS-F14S6G24
4 membres
25 tutoriels rédigés
8 commentaires de tutoriel
I have a first generation Mac Pro (1,1 – 2 x 3GHz Dual-Core Intel Xeon) that I purchased in November 2007.
I still love it.
THANK YOU for your valuable User Guides, and parts replacement guides!
David R Purnell - Réponse Partager
Hi, I just installed Mac OS X High Sierra in my 2010 Mac Pro. The first monitor is active with the ATI Radeon HD5770. However the #2 screen is inactive with its ATI Radeon HD3870. Should I get another HD5770 or a different card so I can use the second screen?
Robert Lloyd - Réponse Partager
For starters this is the first generation forum while your 2010 is a fifth generation model.
Nevertheless I had an interesting situation with the 5770 in a first gen machine that only ran under strange circumstances—a situation wroth sharing nevertheless.:
Ati Radeon X1900Xt had to be installed on bay 1 for the 5770 to work on bay 4
But for your situation, the question is: does the 3870 work standalone in its bay if the 5770 is taken out completely?
And if you swap the graphics cards into each others’ position, what’s the result?
allenwilson33 - Réponse Partager
Hi. My 1st Gen Mac Pro is maxed out with OS X Lion 10.7. I heard I may be able to make it a 5th Gen by switching a chip. Is anyone familiar with this?
Harold L. Watkins - Réponse Partager
Hi, I have a first generation MacBook Pro which is maxed out with OS X Lion 10.7. I heard I may be able to upgrade it to a generation 5 by switching out a chip. Is anyone familiar with this?
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 17
30 derniers jours : 86
Total : 23,945
