Aller au contenu principal
Pour réparer ensemble - Je crée un compte
MacBook Air 13" Early 2015 Heat Sink Replacement
Ce dont vous avez besoin
  1. MacBook Air 13" Early 2015 Heat Sink Replacement, Lower Case: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
    Demander à FixBot
  2. MacBook Air 13" Early 2015 Heat Sink Replacement: étape 2, image 1 de 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    Demander à FixBot
  3. MacBook Air 13" Early 2015 Heat Sink Replacement, Battery Connector: étape 3, image 1 de 2 MacBook Air 13" Early 2015 Heat Sink Replacement, Battery Connector: étape 3, image 2 de 2
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
    Demander à FixBot
  4. MacBook Air 13" Early 2015 Heat Sink Replacement, I/O Board Cable: étape 4, image 1 de 1
    • Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
    Demander à FixBot
  5. MacBook Air 13" Early 2015 Heat Sink Replacement: étape 5, image 1 de 1
    • Carefully peel the I/O board cable from the adhesive securing it to the top of the fan.
    • During reassembly, make sure this cable is in the correct orientation. It will fit if reversed, but the laptop will not boot.
    Demander à FixBot
  6. MacBook Air 13" Early 2015 Heat Sink Replacement: étape 6, image 1 de 2 MacBook Air 13" Early 2015 Heat Sink Replacement: étape 6, image 2 de 2
    • The following connector has an especially deep socket. Use care when disconnecting it.
    • While gently pulling the I/O board cable upward near its connection to the logic board, use the flat end of a spudger to pry up on alternating sides of the connector to help "walk" it out of its socket.
    • Remove the I/O board cable.
    Demander à FixBot
  7. MacBook Air 13" Early 2015 Heat Sink Replacement, Fan: étape 7, image 1 de 1
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    Demander à FixBot
  8. MacBook Air 13" Early 2015 Heat Sink Replacement: étape 8, image 1 de 1
    • Peel the rubber gasket off the adhesive on the top of the fan.
    Demander à FixBot
  9. MacBook Air 13" Early 2015 Heat Sink Replacement: étape 9, image 1 de 1
    • Remove the following three screws securing the fan to the upper case:
    • One 5.2 mm T5 Torx screw
    • One 3.3 mm T5 Torx screw
    • One 4.4 mm T5 Torx screw with a short head
    Demander à FixBot
  10. MacBook Air 13" Early 2015 Heat Sink Replacement: étape 10, image 1 de 2 MacBook Air 13" Early 2015 Heat Sink Replacement: étape 10, image 2 de 2
    • Lift the fan from the I/O board side and pull it free from the upper case.
    • Removing the fan will also disconnect the fan ribbon cable. Be careful not to snag it.
    Demander à FixBot
  11. MacBook Air 13" Early 2015 Heat Sink Replacement, I/O Board: étape 11, image 1 de 1
    • Disconnect the I/O board by pulling its power cable away from its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the right edge of the Air.
    Demander à FixBot
  12. MacBook Air 13" Early 2015 Heat Sink Replacement: étape 12, image 1 de 2 MacBook Air 13" Early 2015 Heat Sink Replacement: étape 12, image 2 de 2
    • Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
    • Pry up from beneath the wires.
    Demander à FixBot
  13. MacBook Air 13" Early 2015 Heat Sink Replacement: étape 13, image 1 de 2 MacBook Air 13" Early 2015 Heat Sink Replacement: étape 13, image 2 de 2
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone ribbon cable ZIF socket.
    • Make sure you are flipping up the retaining flap, not the socket itself.
    Demander à FixBot
  14. MacBook Air 13" Early 2015 Heat Sink Replacement: étape 14, image 1 de 1
    • Remove the single 4.1 mm T5 Torx screw securing the I/O board to the upper case.
    Demander à FixBot
  15. MacBook Air 13" Early 2015 Heat Sink Replacement: étape 15, image 1 de 2 MacBook Air 13" Early 2015 Heat Sink Replacement: étape 15, image 2 de 2
    • Gently de-route the camera cable from its notch on the I/O board and push it out of the way with the tip of a spudger.
    Demander à FixBot
  16. MacBook Air 13" Early 2015 Heat Sink Replacement: étape 16, image 1 de 1
    • Lift the I/O board from the logic board side and pull it free from the upper case.
    • Removing the I/O board will also disconnect the microphone ribbon cable. Be careful not to snag it.
    Demander à FixBot
  17. MacBook Air 13" Early 2015 Heat Sink Replacement, Heat Sink: étape 17, image 1 de 1
    • Remove the two 4.9 mm T8 Torx screws securing the antenna cable retainer on the left display hinge to the upper case.
    Demander à FixBot
  18. MacBook Air 13" Early 2015 Heat Sink Replacement: étape 18, image 1 de 1
    • Push the antenna cable retainer out of the way and remove the single 3 mm T5 Torx screw securing the end of the heat sink to the upper case.
    Demander à FixBot
  19. MacBook Air 13" Early 2015 Heat Sink Replacement: étape 19, image 1 de 1
    • Remove the four 2.5 mm T5 Torx screws securing the heat sink to the logic board.
    Demander à FixBot
  20. MacBook Air 13" Early 2015 Heat Sink Replacement: étape 20, image 1 de 2 MacBook Air 13" Early 2015 Heat Sink Replacement: étape 20, image 2 de 2
    • If the heat sink seems to be stuck to the logic board after removing all five screws, use a spudger to carefully separate the heat sink from the faces of the CPU and GPU.
    • Remove the heat sink from the logic board.
    • When reinstalling the heat sink, be sure to apply a new layer of thermal paste. If you have never applied thermal paste before, we have a guide that makes it easy.
    Demander à FixBot
  21. MacBook Air 13" Early 2015 Heat Sink Replacement: étape 21, image 1 de 2 MacBook Air 13" Early 2015 Heat Sink Replacement: étape 21, image 2 de 2
    • When reassembling your device, attach the gasket to the heat sink as shown.
    • The tail of the gasket should fit into the notch in the heat sink, it should not end up underneath the heat sink tab that will rest on the logic board.
    • Be sure the small post molded into the rubber gasket mates with the hole cut into the upper right corner of the logic board.
    • If you're replacing the heat sink, you can reuse the existing gasket.
    Demander à FixBot
22 autres ont terminé cette réparation.
Sam Goldheart
Membre depuis le 10/18/12
477 327 Réputation
538 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
122 membres
25 805 tutoriels rédigés
6 commentaires de tutoriel
hello if I do not put the gasket in the heatsink that me causes any problem when using the mac?
esg - Réponse Partager
Don’t be lazy and do it right or don’t do it at all. It is not a difficult step and should not be skipped
BRUCEL86 - Réponse Partager
My MAC didn’t have a gasket on the heat sink. It’s not about lazy, it’s about not finding that part. I assume the repair shop didn’t reassemble it correctly, or it came without.
Erin Kaspar-Frett - Réponse Partager
I do not have a gasket on the heat sink either; what does that mean?
Niki - Réponse Partager
The gasket is what is shown in step 8 that surrounds the long heatsink next to the backside of the case. It essentially wraps around the heatsink and rests on top of the small fan. The two purposes of this small gasket is primarily insulate the fan against vibration. The second function is that in some small part it could help provide insulating effects for air flow. This is to ensure that air passes through the fan and out of the rear of the heat exchanger and then out of the back of the laptop.
I suspect it for the first reason I gave primarily and really don’t see an issue as to the performance of the laptop. It just means it might be a little louder with rattle due to vibration.
Justin Hainline - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 39
30 derniers jours : 230
Total : 29,199
