Introduction
Use this guide to replace the MagSafe port in your MacBook Air 15" 2024.
You may need to replace the MagSafe port if your MacBook charges inconsistently or only charges when the charging cable is held in a certain position.
Before replacing the MagSafe port, try using another charger to make sure the issue isn't with your current charger.
Ce dont vous avez besoin
Unplug all cables and fully power off your MacBook.
Close the display and lay your MacBook upside down. Keep your laptop closed until you've physically disconnected the battery.
Use a P5 pentalobe screwdriver to remove the four 6.4 mm‑long screws securing the lower case.
Apply a suction handle to the center of the lower case's front edge.
Pull up on the suction handle to create a gap between the lower case and the frame.
Insert an opening pick into the gap.
Slide the pick to the bottom right corner to release the first clip.
Slide the pick around the corner and up the right edge to release the next two clips.
Keep the lower case flat and firmly pull it straight away from the back edge, one corner at a time, to disengage the sliding tabs.
Remove the lower case.
Set the lower case in place and align the sliding tabs with the screw heads they slide over. Press down and slide the lower case toward the back edge to engage the tabs—it'll stop sliding as the tabs engage.
Once the lower case is flush with the frame, press down firmly along the perimeter to engage the six snapping clips.
Use blunt nose tweezers or your fingers to remove the piece of tape covering the battery connector cover.
Use a T3 Torx screwdriver to remove the two 1.5 mm‑long screws securing the battery connector cover.
Remove the cover.
Use an opening pick to pry up and disconnect the battery connector.
Use a T3 Torx screwdriver to remove the following screws:
Two 2.6 mm‑long screws securing the right hinge cover
Two 1.5 mm‑long screws securing the speaker cable cover
Insert the point of a spudger into one of the right hinge cover's screw holes.
Push the hinge cover away from the back edge to dislodge it.
Remove the hinge cover.
Use the point of a spudger to pry up and disconnect the left speaker press connector.
Use a T5 Torx screwdriver to remove the two screws securing the top edge of the left speaker:
One 2.7 mm‑long screw
One 5.5 mm‑long screw
Use a T6 Torx screwdriver to remove the 3.5 mm‑long screw securing the bottom edge of the speaker.
Lift the speaker's right edge over the frame and slide it to the right to remove it.
Use blunt nose tweezers or your fingers to peel up and remove the tape.
Use a spudger to pry up and disconnect the MagSafe port press connector.
Slowly peel the MagSafe port cable from the frame to separate the adhesive securing it.
If your new MagSafe port's cable comes with adhesive, remove the plastic liner and press the cable into place on the frame.
If the cable doesn't have adhesive, use a strip of double-sided tape to secure it to the frame.
Use a T3 Torx screwdriver to remove the two 3.3 mm‑long screws securing the metal wedge to the MagSafe port.
Use a T5 Torx screwdriver to remove the two 2.7 mm‑long screws securing the MagSafe port to the frame.
Insert the port and partially tighten the two 2.7 mm‑long screws that secure its left edge.
Properly align the port and fully tighten its screws.
Put the wedge into place on top of the MagSafe port and partially tighten its two 3.3 mm‑long screws.
Push the wedge under the lip of the frame and fully tighten its screws.
