Aller au contenu principal
MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement
Ce dont vous avez besoin
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
    • Two 6.7 mm screws
    • Four 3.4 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  1. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Open a gap using a suction cup: étape 2, image 1 de 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Open a gap using a suction cup: étape 2, image 2 de 2
    • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
    • Lift the suction handle to create a slight gap between the lower case and the chassis.
  2. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the clips: étape 3, image 1 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the clips: étape 3, image 2 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the clips: étape 3, image 3 de 3
    • Insert one corner of an opening pick into the space between the lower case and the chassis.
    • Slide the opening pick around the nearest corner and halfway up the side of the case.
    • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
  3. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 4, image 1 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 4, image 2 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 4, image 3 de 3
    • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
  4. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 5, image 1 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 5, image 2 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 5, image 3 de 3
    • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
    • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
    • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
  5. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 6, image 1 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 6, image 2 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 6, image 3 de 3
    • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This can require a lot of force.
  6. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Remove the lower case: étape 7, image 1 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Remove the lower case: étape 7, image 2 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Remove the lower case: étape 7, image 3 de 3
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
  7. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Uncover the battery connector: étape 8, image 1 de 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Uncover the battery connector: étape 8, image 2 de 2
    • Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
    • Remove the tape.
  8. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 9, image 1 de 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 9, image 2 de 2
    • Gently peel back the small piece of tape covering the battery board data cable connector.
    • The tape is integrated into the ribbon cable and will not detach completely. Simply peel it back enough to access the connector.
  9. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 10, image 1 de 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 10, image 2 de 2
    • Use the tip of a spudger to flip up the small black locking tab securing the cable in its connector.
  10. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 11, image 1 de 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 11, image 2 de 2
    • Disconnect the battery board data cable by sliding it out from its socket.
    • Slide parallel to the logic board, in the direction of the cable.
  11. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 12, image 1 de 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 12, image 2 de 2
    • Fold the battery board data cable to the side and out of the way.
  12. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 13, image 1 de 1
    • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
  13. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Disconnect the battery: étape 14, image 1 de 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Disconnect the battery: étape 14, image 2 de 2
    • Use a spudger to gently lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
  14. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Remove the trackpad connector screws: étape 15, image 1 de 1
    • Use a T3 Torx driver to remove the two 1.8 mm screws securing the trackpad cable connector bracket.
  15. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 16, image 1 de 1
    • Remove the trackpad cable connector bracket with a pair of tweezers.
  16. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Disconnect the trackpad: étape 17, image 1 de 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Disconnect the trackpad: étape 17, image 2 de 2
    • Use a spudger to disconnect the trackpad ribbon cable by gently prying its connector straight up from the logic board.
  17. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Heat the trackpad cable: étape 18, image 1 de 1
    • Prepare an iOpener and lay it on top of the trackpad ribbon cable for about a minute, in order to soften the adhesive securing the trackpad ribbon cable to the top of the battery.
    • If you don't have an iOpener, use a hair dryer to warm up the cable instead. The cable should be warm, but not too hot to touch. Be careful not to overheat the battery.
  18. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Peel up the trackpad cable: étape 19, image 1 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Peel up the trackpad cable: étape 19, image 2 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Peel up the trackpad cable: étape 19, image 3 de 3
    • Carefully peel the trackpad ribbon cable up off the battery, and push it out of the way.
    • Do not fold or tear the cable.
  19. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Remove the trackpad screws: étape 20, image 1 de 1
    • Use a T5 Torx driver to remove the ten screws securing the trackpad assembly:
    • Two 4.3 mm screws
    • Eight 5.8 mm screws
  20. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 21, image 1 de 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 21, image 2 de 2
    • Swing the display open slightly to access the trackpad.
    • Carefully thread the trackpad ribbon cable out through the hole in the MacBook Pro's frame.
  21. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 22, image 1 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 22, image 2 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 22, image 3 de 3
    • Remove the trackpad assembly.
    • Be sure not to lose the six small washers (two circular and four rectangular) resting on the underside of the trackpad.
  22. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Unscrew the battery board: étape 23, image 1 de 1
    • Use a T5 Torx driver to remove the two 3.2 mm screws from the battery board.
  23. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Protect the display and keyboard: étape 24, image 1 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Protect the display and keyboard: étape 24, image 2 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Protect the display and keyboard: étape 24, image 3 de 3
    • The liquid adhesive remover provided in your kit can cause damage if it contacts the MacBook Pro's display or keyboard.
    • To protect your display, place a sheet of aluminum foil between the display and keyboard and leave it there while you work.
    • Additionally, use some tape and/or foil to seal off the area under the trackpad. Optionally, you may also layer an absorbent towel directly underneath the trackpad area to soak up any excess adhesive remover.
  24. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Protect the speakers: étape 25, image 1 de 1
    • Before removing the battery, it's important to protect the speakers on either side. The speakers are glued down just like the battery—so if the liquid adhesive remover gets under the speakers, they may come loose and rattle after your repair.
    • Cut a length of packing tape or painter's tape, and slide one edge between the battery and the speaker on the left side.
  25. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 26, image 1 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 26, image 2 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 26, image 3 de 3
    • Press all along the edge of the tape with your spudger to stick it securely to the MacBook Pro's aluminum case, sealing off the speaker from the battery.
    • Be careful not to poke or puncture the battery.
    • Fold the tape over and lightly adhere it to the speaker to keep it out of the way.
    • The foam bumpers on top of the speaker may tear when peeling the tape off. Don't press the tape directly onto the bumpers.
  26. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 27, image 1 de 1
    • Repeat the previous two steps on the opposite side in order to seal off the other speaker from the battery.
  27. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Elevate the right edge: étape 28, image 1 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Elevate the right edge: étape 28, image 2 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Elevate the right edge: étape 28, image 3 de 3
    • To control the flow of adhesive remover and direct it away from the speaker, raise the right edge of your MacBook Pro a few inches using a book or foam block.
  28. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Protect your eyes and skin: étape 29, image 1 de 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Protect your eyes and skin: étape 29, image 2 de 2
    • Now that your MacBook Pro is fully prepped, it's time to prep yourself.
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • Do not wear contact lenses without eye protection.
    • Protective gloves are also included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
  29. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Open the adhesive remover: étape 30, image 1 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Open the adhesive remover: étape 30, image 2 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Open the adhesive remover: étape 30, image 3 de 3
    • Pull off the black rubber stopper from your bottle of adhesive remover.
    • Twist to loosen or remove the bottle cap before you cut the applicator tip.
    • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
    • Use scissors to cut off the sealed tip of the applicator.
    • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
    • Twist and close the bottle cap securely before you proceed further.
  30. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Apply the adhesive remover: étape 31, image 1 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Apply the adhesive remover: étape 31, image 2 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Apply the adhesive remover: étape 31, image 3 de 3
    • Apply a few drops of adhesive remover underneath the far right battery cell.
    • You don't need to use very much—the small bottle contains more than twice the amount of solvent needed to remove all the battery cells.
    • Wait about two minutes for the adhesive remover to penetrate and soften the battery adhesive before you proceed to the next step.
  31. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the outside right battery cell: étape 32, image 1 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the outside right battery cell: étape 32, image 2 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the outside right battery cell: étape 32, image 3 de 3
    • After a couple minutes, insert one corner of a plastic card underneath the far right battery cell, starting from the front edge.
    • This shouldn't require much force. If you have trouble, apply more adhesive remover and give it 2-3 additional minutes to penetrate.
    • Try not to deform the battery. A damaged battery can leak dangerous chemicals and/or catch fire.
    • Wiggle the card from side to side and slide it all the way under the battery cell.
    • Lift to fully separate the adhesive, but don't try to remove the battery cell yet.
    • Leave the plastic card temporarily underneath the cell to prevent it from re-adhering while you continue.
  32. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Alternative: separate the battery cell with floss: étape 33, image 1 de 1
    • If you have difficulty getting the card underneath any of the battery cells, try working a piece of floss or wire underneath the battery cell. Pull it side-to-side in a sawing motion to separate the adhesive.
    • Wear thick gloves or wrap the floss around a couple of driver handles so as not to hurt your fingers.
  33. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Elevate the left edge: étape 34, image 1 de 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Elevate the left edge: étape 34, image 2 de 2
    • Repeat the last few steps to separate the far left battery cell.
    • Begin by elevating the left side of the MacBook Pro to direct the flow of adhesive remover away from the speaker.
  34. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Apply adhesive remover: étape 35, image 1 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Apply adhesive remover: étape 35, image 2 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Apply adhesive remover: étape 35, image 3 de 3
    • Apply a few drops of adhesive remover under the far left battery cell, and wait about two minutes for it to penetrate.
  35. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the outer left cell: étape 36, image 1 de 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the outer left cell: étape 36, image 2 de 2
    • Slide one corner of a plastic card underneath the far left battery cell, and carefully separate the adhesive holding it in place.
  36. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Elevate the back edge: étape 37, image 1 de 1
    • Next, raise the back edge of your MacBook Pro to direct the flow of adhesive remover away from the keyboard/logic board area.
  37. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Apply adhesive remover: étape 38, image 1 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Apply adhesive remover: étape 38, image 2 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Apply adhesive remover: étape 38, image 3 de 3
    • Apply a few drops of adhesive remover under each of the remaining three battery cells.
    • There are openings in the aluminum case underneath these cells, so some of the adhesive remover may leak out instead of penetrating underneath the battery.
    • Be mindful of leaks, and apply more adhesive remover in the following steps if needed.
    • Wait about two minutes before you continue.
  38. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the inner left cell: étape 39, image 1 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the inner left cell: étape 39, image 2 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the inner left cell: étape 39, image 3 de 3
    • The remaining two smaller battery cells each sit on a slightly raised portion of the MacBook's aluminum frame.
    • Slide a plastic card all the way underneath the far left battery cell—which you already separated in the previous steps—and then insert it carefully between the remaining left-side battery cell and the MacBook Pro's aluminum case.
  39. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 40, image 1 de 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: étape 40, image 2 de 2
    • Use your plastic card to fully separate the remaining battery cell on the left side.
    • Take care to not pry against the logic board.
    • Leave your plastic card in place temporarily to prevent the left-side battery cells from re-adhering.
  40. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the inner right cell: étape 41, image 1 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the inner right cell: étape 41, image 2 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the inner right cell: étape 41, image 3 de 3
    • Repeat the previous two steps to separate the remaining battery cell on the right.
  41. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the middle cells: étape 42, image 1 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the middle cells: étape 42, image 2 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the middle cells: étape 42, image 3 de 3
    • The final battery cells can be more difficult to remove. If needed, apply more adhesive remover to make the job easier.
    • Slide the corner of one of your plastic cards underneath the top edge of one of the cells and then work it underneath the other cell.
    • Wiggle the card from side to side and slide it underneath the battery cells to fully separate the adhesive holding them in place.
  42. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Remove the battery: étape 43, image 1 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Remove the battery: étape 43, image 2 de 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Remove the battery: étape 43, image 3 de 3
    • Before you remove the battery, ensure that the battery connector is sufficiently raised and not in the way of the battery board.
    • Remove the battery.
    • Before installing a new battery, remove all remaining adhesive from the MacBook Pro's case.
    • Peel off any large strips of adhesive using tweezers or gloved fingers.
    • Scrape away any remaining chunks of adhesive with a plastic tool, and clean the underlying areas with adhesive remover or isopropyl alcohol. Wipe in one direction (not back and forth) until the chassis is clean and ready for your new battery.
    • This can take quite a bit of work, so be patient.
    • When you're done, carefully remove the protective tape from the speakers.
    • Double-check the fit and alignment of your new battery before sticking it down.
    • Be mindful of the battery data cable and make sure it doesn't get pinched or trapped under the battery board.
    • If your battery came with adhesive pre-installed on the bottom, flip it over and carefully peel away the liner to expose the adhesive. If your battery did not come with adhesive, apply a thin double-sided adhesive tape such as Tesa 61395 to keep your battery in place.
    • Carefully position the battery and set it into place.
    • Press and hold each cell firmly for 5-10 seconds to secure it to the lower case.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
8 autres ont terminé cette réparation.
Carsten Frauenheim
Membre depuis le 03/10/20
105 103 Réputation
338 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
140 membres
15 216 tutoriels rédigés
Un commentaire
Thank you I don’t own this but this repair was easy to understand and well written. Keep up the good work!🤓😆🦆
dan g - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 17
7 derniers jours : 170
30 derniers jours : 903
Total : 20,539
