Aller au contenu principal
Remplacement de la RAM des MacBook Pro 15" Core 2 Duo, modèles A1226 et A1260
Ce dont vous avez besoin
  1. Remplacement de la RAM des MacBook Pro 15" Core 2 Duo, modèles A1226 et A1260, Batterie: étape 1, image 1 de 3 Remplacement de la RAM des MacBook Pro 15" Core 2 Duo, modèles A1226 et A1260, Batterie: étape 1, image 2 de 3 Remplacement de la RAM des MacBook Pro 15" Core 2 Duo, modèles A1226 et A1260, Batterie: étape 1, image 3 de 3
    • Poussez avec les doigts les deux loquets de déverrouillage de la batterie et retirez celle-ci de l'ordinateur.
    Before start, make a clone of your old HD into the new one, if you don't want to initiate a fresh copy. (Carbon Copy software is good).
    ColmillodeChile - Réponse
    Besides using WD 500GB models, are the WD 640GB and WD 750GB (the 9.5mm thickness model) good to go for? I am still considering as I have heard from other websites on the computer does not draw enough power to power up the 640 and 750 as it has the clicking sound and the rainbow keeps appearing. Anyone has install one before yet?
    Please advice. Appreciated! Thanks a million to all the Mac gurus out there!
    Danny Lim -
    Citation de ColmillodeChile :
    What is this about removing the PRAM battery causing a reinitialization of the HDD? For serious?
    Adrian - Réponse
    No, that's nonsense
    max damage -
    Citation de Adrianthomaspre :
    Wait, I misunderstood you. I thought the comment was directed at the PRAM battery removal page. Silly me.
    Nevermind. Yes, it is always a good idea to backup one's data before doing stuff like this. I never do, and have never had any problems, but it's still a good idea.
    Adrian - Réponse
    The two screws removed in step 3 should not be mixed with screws in steps 5 through 7. Though similar, they are actually slightly shorter and have a bigger head. If you put the longer screws back in here when reassembling, the button to unlatch the top will not work properly.
    Doug - Réponse
    Citation de Doug :
    I think you may have commented on the wrong page. This page only has 3 steps, and the screws are removed in step 2, not 3.
    (Remplacement de la RAM des MacBook Pro 15" Core 2 Duo, modèles A1226 et A1260)
    Don - Réponse
    I'm not sure how the user notes get attached to the various procedures here, but my comment does seem to show up properly when viewing the steps for Hard Drive Replacement. However, the number of the step may be off if viewed as part of another procedure.
    Citation de Don :
    Doug - Réponse
  2. Remplacement de la RAM des MacBook Pro 15" Core 2 Duo, modèles A1226 et A1260, Capot de protection RAM: étape 2, image 1 de 2 Remplacement de la RAM des MacBook Pro 15" Core 2 Duo, modèles A1226 et A1260, Capot de protection RAM: étape 2, image 2 de 2
    • Retirez les trois vis identiques Phillips de 2 mm du capot de la mémoire.
    • Soulevez le capot suffisamment pour le saisir et retirez-le en le faisant glisser vers vous.
    These screws are different from the rest, they should be kept separate from the others.
    foregoing-celery - Réponse
    Replacing RAM on an A1226: The instructions said Phillips #00, but the screwdriver that fit the RAM Shield screws for me was a Phillips #0.
    dlyons - Réponse
    Concur, my screws were Phillips #0 as
    Lee Haelters - Réponse
  3. Remplacement de la RAM des MacBook Pro 15" Core 2 Duo, modèles A1226 et A1260, RAM: étape 3, image 1 de 2 Remplacement de la RAM des MacBook Pro 15" Core 2 Duo, modèles A1226 et A1260, RAM: étape 3, image 2 de 2
    • Écartez simultanément les clips de chaque côté de la barrette de RAM. Ces clips maintiennent la barrette en place et lorsque vous les écartez, la barrette se débloque.
    • Tirez la barrette hors de son connecteur.
    • Si deux barrettes de RAM sont installées, répétez la procédure ci-dessus pour la seconde barrette.
Pour remonter votre appareil, suivez les mêmes instructions dans l'ordre inverse.
222 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Un commentaire
Really easy to install RAM on Macbook Pro 15'' Model A1226!!
I had 2GB of RAM (1GB and 1GB), so when I read this tutorial I decided to buy one ram of 2GB 667Mhz and It is working great (now I've got a total of 3 GB). I'm willing to install up to 6 GB with this same tutorial. Recommended!
cesrafa - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 15
30 derniers jours : 98
Total : 132,838
