Introduction
Use this guide to replace the battery in your MacBook Pro 16" 2021.
The MacBook Pro uses stretch-release adhesives to secure the battery. Some of the strips are hidden underneath the trackpad, so you’ll need to remove it first to access the strips.
For your safety, discharge the battery below 25% before disassembling your MacBook. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
You'll need replacement adhesive in order to complete this repair.
Ce dont vous avez besoin
Outil utilisé dans cette étape :Magnetic Project Mat$19.95
Use a P5 Pentalobe driver to remove eight screws securing the lower case:
Four 9.1 mm screws
Four 5 mm screws
Press a suction handle into place near the front edge of the lower case, between the screw holes.
Pull up on the suction handle to create a small gap under the lower case.
Insert an opening pick into the gap you just created.
Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
Repeat the previous step on the other side, using an opening pick to to release the second clip.
Remove the lower case.
Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
Étape 7 Disconnect the battery board
Attention : les étapes 7 à 19 sont issues d'un tutoriel marqué comme en cours.
Peel back any tape covering the battery board data cable connector on the logic board.
Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
Use a T3 Torx driver to remove the two 2.1 mm‑long screws securing the trackpad cable bracket to the logic board.
Use tweezers, or your fingers, to remove the trackpad cable bracket.
Use the flat end of a spudger to pry up and disconnect the trackpad cable's press connector from the logic board.
Peel the trackpad cable away from the device, making sure to separate the adhesive.
Peel back any tape covering the battery board data cable connector under the large pancake screw.
Slide blunt nose tweezers under areas with adhesive to separate the cable from the device.
Remove the battery board data cable.
Use a T5 Torx driver to remove the 3.9 mm pancake screw securing the battery power connector.
Use a spudger to lift the battery power connector, disconnecting the battery.
Use a T5 Torx driver to remove the 13 screws securing the trackpad assembly:
Ten 5 mm screws
Three 5.8 mm screws
Swing the display open slightly, but keep the MacBook upside-down. The trackpad assembly should separate and lay flat on the display.
Carefully feed the trackpad's ribbon cable through its slot in the frame.
Use a T5 Torx driver to remove the two screws securing the battery board:
One 4.4 mm screw
One 3.8 mm screw
There are eight adhesive strips that are accessed from the bottom of the device.
There are six more adhesive strips accessed from the trackpad's location on the frame.
Use tweezers, or your fingers, to grasp the black pull-tab on one of the adhesive strips.
Pull the strip out slowly and steadily at a low angle. Give it plenty of time to stretch and un-stick from under the battery.
If the adhesive strip breaks off, try to retrieve it using your fingers or blunt tweezers, and continue pulling—but do not pry under the battery.
Repeat the process for all 14 stretch release adhesive strips.
Outil utilisé dans cette étape :Plastic Cards$2.99
Insert a plastic card between the battery and the frame.
Pry up with the card while slicing the adhesive to separate the battery from the frame.
For optimal performance, calibrate your newly installed battery after completing this guide.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 16" 2021 Answers community for help.
16 autres ont terminé cette réparation.
11 commentaires
This is what I search for! Such a great guide!
Hi there!
Unfortunately, we are not currently selling MacBook Pro 16" 2021 batteries. We are hoping to sell them sometime soon. You may want to consider checking with other retailers or online sources for the specific battery you need.
