Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Magic Bullet MB1001B Activator Replacement
Ce dont vous avez besoin
    1. Magic Bullet MB1001B Activator Replacement, Base Gear: étape 1, image 1 de 3 Magic Bullet MB1001B Activator Replacement, Base Gear: étape 1, image 2 de 3 Magic Bullet MB1001B Activator Replacement, Base Gear: étape 1, image 3 de 3
      • Use pliers to grip the gear inside of the top of the device.
      • You may have to remove a sticker that is covering the slit at the center of the bottom before completing the next step.
      • Insert a flathead screwdriver into the slit at the bottom of the device while still holding the pliers in place gripped on the gear.
      • Lay the device on its side. Holding the screwdriver stationary to hold the bottom side in place, use the pliers to unscrew the gear by turning the pliers CLOCKWISE.
      Demander à FixBot
      Ajouter un commentaire
    1. Magic Bullet MB1001B Activator Replacement, Casing: étape 2, image 1 de 1
      • Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
      Demander à FixBot
    2. Magic Bullet MB1001B Activator Replacement: étape 3, image 1 de 1
      • Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
      Demander à FixBot
    3. Magic Bullet MB1001B Activator Replacement: étape 4, image 1 de 1
      • Remove the black base plate.
      Demander à FixBot
    4. Magic Bullet MB1001B Activator Replacement: étape 5, image 1 de 1
      • Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
      Demander à FixBot
    5. Magic Bullet MB1001B Activator Replacement: étape 6, image 1 de 1
      • Remove the white plastic cable guide.
      Demander à FixBot
    6. Magic Bullet MB1001B Activator Replacement: étape 7, image 1 de 1
      • Remove the three 11.0 mm Phillips head screws surrounding the white fan blade on the base using the Phillips #1 screwdriver.
      Demander à FixBot
    7. Magic Bullet MB1001B Activator Replacement: étape 8, image 1 de 1
      • Remove the black base.
      Demander à FixBot
    8. Magic Bullet MB1001B Activator Replacement: étape 9, image 1 de 1
      • Remove the three white rubber spacers with the spudger.
      Demander à FixBot
    9. Magic Bullet MB1001B Activator Replacement: étape 10, image 1 de 1
      • Remove the three 11.0 mm Phillips head screws using the Phillips #1 screwdriver.
      Demander à FixBot
    10. Magic Bullet MB1001B Activator Replacement: étape 11, image 1 de 1
      • Remove the motor.
      Demander à FixBot
    1. Magic Bullet MB1001B Activator Replacement, Activator: étape 12, image 1 de 2 Magic Bullet MB1001B Activator Replacement, Activator: étape 12, image 2 de 2
      • Wedge a flathead screwdriver in between the casing and white plastic activator.
      • Pry the white plastic activators from the casing as needed.
      Demander à FixBot
3 autres ont terminé cette réparation.
Aubree Duran
Membre depuis le 10/06/15
390 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 12-13, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 12-13, Maness Fall 2015
CPSU-MANESS-F15S12G13
4 membres
20 tutoriels rédigés
4 commentaires de tutoriel
You gotta be kidding me?
marcomolinero72 - Réponse Partager
Right. Steps on how to fix their faulty machine. And worse. Selling you the tools to do it for only 29.99!
Del - Réponse Partager
Where would you get replacement activators or spring beneath these? How much would that cost?
Spartan 1293 - Réponse Partager
Oh, my gosh! I’ll just throw this thing away and use my blender!
txberta - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 14
30 derniers jours : 67
Total : 10,124
