Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Magic Bullet NutriBullet Pro Activator Replacement
Ce dont vous avez besoin
  1. Magic Bullet NutriBullet Pro Activator Replacement, Magic Bullet NutriBullet Pro Disassembly: étape 1, image 1 de 3 Magic Bullet NutriBullet Pro Activator Replacement, Magic Bullet NutriBullet Pro Disassembly: étape 1, image 2 de 3 Magic Bullet NutriBullet Pro Activator Replacement, Magic Bullet NutriBullet Pro Disassembly: étape 1, image 3 de 3
    • To start the disassembly of the Magic Bullet NutriBullet Pro you will begin from the bottom.
    • Flip the device over to the bottom.
    • Unscrew the four 1 cm screws using #2 Phillips Head Screwdriver.
    • Remove the loose bottom portion of the device by pulling up from the bottom.
    Demander à FixBot
    Ajouter un commentaire
  2. Magic Bullet NutriBullet Pro Activator Replacement: étape 2, image 1 de 2 Magic Bullet NutriBullet Pro Activator Replacement: étape 2, image 2 de 2
    • Unscrew the two 1 cm screws holding down the power cord using the #2 Phillips Head Screwdriver.
    Demander à FixBot
  3. Magic Bullet NutriBullet Pro Activator Replacement: étape 3, image 1 de 3 Magic Bullet NutriBullet Pro Activator Replacement: étape 3, image 2 de 3 Magic Bullet NutriBullet Pro Activator Replacement: étape 3, image 3 de 3
    • Unscrew the three 1 cm screws on the device circled on the screws pictures using the #1 Philips Head Screwdriver.
    • Lift off the grey plastic piece off.
    • Slide off the silver metal piece.
    Demander à FixBot
  4. Magic Bullet NutriBullet Pro Activator Replacement: étape 4, image 1 de 2 Magic Bullet NutriBullet Pro Activator Replacement: étape 4, image 2 de 2
    • Flip the device over.
    • Remove the three rubber seals covering the screws by pulling the components upward with the tweezer.
    • Unscrew the three 16 mm screws using the #2 Phillips Head Screwdriver.
    Demander à FixBot
  5. Magic Bullet NutriBullet Pro Activator Replacement: étape 5, image 1 de 2 Magic Bullet NutriBullet Pro Activator Replacement: étape 5, image 2 de 2
    • Pull off the casing from the device.
    Demander à FixBot
  6. Magic Bullet NutriBullet Pro Activator Replacement, Activator: étape 6, image 1 de 2 Magic Bullet NutriBullet Pro Activator Replacement, Activator: étape 6, image 2 de 2
    • Remove the two 8 mm screws using the #2 Phillips Head Screwdriver while holding the activator in place.
    • There are three separate activators with two screws each.
    Demander à FixBot
  7. Magic Bullet NutriBullet Pro Activator Replacement: étape 7, image 1 de 1
    Outil utilisé dans cette étape :
    • Be careful of the spring flying out.
    • Lift activator out of the Magic Bullet housing while holding the spring with tweezers.
    Demander à FixBot
6 autres ont terminé cette réparation.
Malcolm Smith Fraser
Membre depuis le 10/03/16
284 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 18-4, Forte Fall 2016 Membre de l'équipe Cal Poly, Team 18-4, Forte Fall 2016
CPSU-FORTE-F16S18G4
4 membres
8 tutoriels rédigés
8 commentaires de tutoriel
Where can I buy the actual activator?? Two on my nutribullet broke from the base.
Ed David - Réponse Partager
Can you direct me to where I can buy spare parts for this bullet? As I need to replace the three black plastic moving parts that are pressed down by the lid that activates the switches.
Thankyou fir this great guide
Tony Chadwick - Réponse Partager
Please can you direct me to where i can buy soare parts for this Bullet?
I need to replace the worn out 3 black plastic sliders that are pressed down by by the lid to activate it.
Many thanks
Tony
1. How do I know if culprit is activators? My spice grinder blade works, but not the blender blade and extra I bought
2. If it IS activator, do I need to buy new ones? Or just reassemble with original parts?
sharipaula - Réponse Partager
I thought it was the activators, since they were pretty gummed up from use. However, I believe the culprit is the mounting posts for the motor. They have rubber grommets attached to control vibration and all three of the posts the grommets go over have snapped off the mounting plate :(
I’ll try superglue, but don’t think it’s going to hold.
I’d like to remove the motor shaft from the top plate, but don’t see a way how to do that.
twhitehead928 - Réponse Partager
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 17
30 derniers jours : 105
Total : 15,958
