Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Micro-USB Port Replacement
Ce dont vous avez besoin
    1. Micro-USB Port Replacement, Back Plate: étape 1, image 1 de 2 Micro-USB Port Replacement, Back Plate: étape 1, image 2 de 2
      • Unscrew the four 3.4 mm flat head screws
      Demander à FixBot
      Ajouter un commentaire
    2. Micro-USB Port Replacement: étape 2, image 1 de 1
      • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
      Demander à FixBot
    1. Micro-USB Port Replacement, Lithium Battery: étape 3, image 1 de 1
      • If not replacing lithium battery, skip down two steps.
      • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
      Demander à FixBot
    2. Micro-USB Port Replacement: étape 4, image 1 de 1
      • Desolder the battery connections from the motherboard. Learn how to solder components here!
      Demander à FixBot
    1. Micro-USB Port Replacement, Motherboard: étape 5, image 1 de 1
      • Use PH00 screw driver to remove two 2.4mm Phillips head screws.
      Demander à FixBot
    2. Micro-USB Port Replacement: étape 6, image 1 de 1
      Outil utilisé dans cette étape :
      • Use a spudger or tweezers to remove a white sticker that covers a Phillips head screw.
      Demander à FixBot
    3. Micro-USB Port Replacement: étape 7, image 1 de 1
      • Use PH00 screwdriver to remove 5.2mm Phillips head screw
      Demander à FixBot
    4. Micro-USB Port Replacement: étape 8, image 1 de 3 Micro-USB Port Replacement: étape 8, image 2 de 3 Micro-USB Port Replacement: étape 8, image 3 de 3
      • Use ESD safe tweezers to remove the gold ribbon cable.
      • This will expose a second 5.2mm Phillips head screw that can be removed with a PH00 screwdriver.
      Demander à FixBot
    5. Micro-USB Port Replacement: étape 9, image 1 de 2 Micro-USB Port Replacement: étape 9, image 2 de 2
      • Use a spudger to gently pry on the motherboard towards the top of the watch, being towards the 12 o'clock position to loosen the motherboard.
      • You can now access the parts and pieces on the bottom of, and below the motherboard.
      Demander à FixBot
    1. Micro-USB Port Replacement, Micro-USB Port: étape 10, image 1 de 1
      • Locate the four main soldering points marked in red.
      • Be aware of the five additional soldered pins marked by the blue arrow.
      Demander à FixBot
    2. Micro-USB Port Replacement: étape 11, image 1 de 3 Micro-USB Port Replacement: étape 11, image 2 de 3 Micro-USB Port Replacement: étape 11, image 3 de 3
      • Begin to desolder the points pointed out in the last step.
      • Use the soldering wick to help remove the solder.
      Demander à FixBot
3 autres ont terminé cette réparation.
Michael Miller
Membre depuis le 10/24/16
281 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 3-3, Baechle Fall 2016 Membre de l'équipe IUPUI, Team 3-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G3
4 membres
22 tutoriels rédigés
1 commentaire de tutoriel
I want to know that what I have to do if want to replace the lithium battery with usb direct powered device.
amupis232389 - Réponse Partager
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 23
30 derniers jours : 87
Total : 18,403
