Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Microsoft Band Battery Replacement
Ce dont vous avez besoin
    1. Microsoft Band Battery Replacement, Battery: étape 1, image 1 de 1
      • Unscrew both side panel 2mm screws using the T3 Torx screwdriver.
      Demander à FixBot
      Ajouter un commentaire
    2. Microsoft Band Battery Replacement: étape 2, image 1 de 1
      • Firmly pry up the side panel using the plastic spudger to break the waterproof seal and lift the battery panel.
      Demander à FixBot
    3. Microsoft Band Battery Replacement: étape 3, image 1 de 1
      • Gently pry up one edge of the battery with the plastic spudger.
      Demander à FixBot
    4. Microsoft Band Battery Replacement: étape 4, image 1 de 1
      • Remove battery from its compartment with your fingers.
      Demander à FixBot
To reassemble your device, follow these instructions in reverse order. Replace the vibrator in its original compartment.
5 autres ont terminé cette réparation.
Monique Salinger
Membre depuis le 02/01/15
408 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 17-34, Amido Winter 2015 Membre de l'équipe Cal Poly, Team 17-34, Amido Winter 2015
CPSU-AMIDO-W15S17G34
4 membres
6 tutoriels rédigés
5 commentaires de tutoriel
where can i buy the battery?
chirac - Réponse Partager
From what I can tell it's something like this:
http://www.alibaba.com/product-detail/Ho...
which is a 3.7v flat lithium ion polymer 72mAh battery. Min order is 1030 though! You can find similar on AliExpress if you search for that description. The dimensions are listed as 4*14.8*21.5mm so it'll need to be within that, or maybe the OP can confirm the battery size?
Simon - Réponse Partager
Will this be dangerous?
Rei zzstu Shiozawa - Réponse Partager
Anyway to upgrade to a higher capacity battery to get better life out of it? With GPS on, it dies in 2 hours and I go on 8 hr hikes.
Chris Green - Réponse Partager
No tak wszystko fajnie ale gdzie te akumulatory zakupić ?
Tomasz Sot - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 53
Total : 12,589
