Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Microsoft Kinect Motherboard Replacement
Ce dont vous avez besoin
  1. Microsoft Kinect Motherboard Replacement, Case: étape 1, image 1 de 3 Microsoft Kinect Motherboard Replacement, Case: étape 1, image 2 de 3 Microsoft Kinect Motherboard Replacement, Case: étape 1, image 3 de 3
    • Remove the two plastic strips off the bottom of the main Kinect housing using the metal spudger's sharper side.
    • Peel off the two Xbox 360 stickers from the bottom of the case to reveal two hidden screws.
    • Some force may be required to remove the adhesive. Applying heat to the adhesive may make it easier to remove.
    • Do not overheat as it may cause damage to the internal components.
    Demander à FixBot
    Ajouter un commentaire
  2. Microsoft Kinect Motherboard Replacement: étape 2, image 1 de 1
    • Unscrew the six 12mm T10 Torx screws.
    Demander à FixBot
  3. Microsoft Kinect Motherboard Replacement: étape 3, image 1 de 3 Microsoft Kinect Motherboard Replacement: étape 3, image 2 de 3 Microsoft Kinect Motherboard Replacement: étape 3, image 3 de 3
    • Remove the top portion of the case from the rest of the body.
    • Detach the side portions of the case from the body.
    • Remove the fan piece from the side of the body. Unplug it from the logic board to fully remove it.
    • When unplugging the fan, be sure to pull from the white connector at the end of the wire to avoid breaking it.
    Demander à FixBot
  4. Microsoft Kinect Motherboard Replacement: étape 4, image 1 de 1
    • Remove the bottom portion of the case by sliding it out from under the body.
    • The bottom of the case may be difficult to remove if there is any residual adhesive. If the residual adhesive prevents you from removing the case, apply gentle heat and wiggle the case out.
    Demander à FixBot
  5. Microsoft Kinect Motherboard Replacement: étape 5, image 1 de 2 Microsoft Kinect Motherboard Replacement: étape 5, image 2 de 2
    • Remove the four 7mm T10 Torx screws (two on each side of the metal body).
    Demander à FixBot
  6. Microsoft Kinect Motherboard Replacement: étape 6, image 1 de 2 Microsoft Kinect Motherboard Replacement: étape 6, image 2 de 2
    • Remove the front portion of the case containing the lens coverings for the cameras.
    • The LED component is connected to the front portion of the case. To disconnect it, just pull it out of its plastic connector.
    Demander à FixBot
  7. Microsoft Kinect Motherboard Replacement, Microphone Panel: étape 7, image 1 de 1
    • Unplug the microphone from motherboard.
    Demander à FixBot
  8. Microsoft Kinect Motherboard Replacement: étape 8, image 1 de 1
    • Pull off the microphone panel and snake the cable that was connected to the motherboard through the hole on the camera panel.
    • Pull the cable out carefully to avoid damage.
    Demander à FixBot
  9. Microsoft Kinect Motherboard Replacement, Motherboard: étape 9, image 1 de 1
    • Unscrew the seven 6.5mm T10 Torx screws.
    Demander à FixBot
  10. Microsoft Kinect Motherboard Replacement: étape 10, image 1 de 1
    • Disconnect the bridge connecting the first and second layer of the motherboard.
    • Pull the first layer of the motherboard off.
    Demander à FixBot
  11. Microsoft Kinect Motherboard Replacement: étape 11, image 1 de 1
    • Unplug the LED cable from the motherboard.
    Demander à FixBot
  12. Microsoft Kinect Motherboard Replacement: étape 12, image 1 de 1
    • Unscrew the three 16.5mm screws using the 5mm Nut Driver.
    • Unscrew the one 6.5mm T10 Torx screw.
    Demander à FixBot
  13. Microsoft Kinect Motherboard Replacement: étape 13, image 1 de 2 Microsoft Kinect Motherboard Replacement: étape 13, image 2 de 2
    • Remove the three ribbon cables.
    • Disconnect the left most camera from the motherboard.
    Demander à FixBot
2 autres ont terminé cette réparation.
Nick Carlucci
Membre depuis le 04/26/15
394 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 14-7, Amido Spring 2015 Membre de l'équipe Cal Poly, Team 14-7, Amido Spring 2015
CPSU-AMIDO-S15S14G7
4 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 83
Total : 2,414
