Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement
Ce dont vous avez besoin
  1. Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Prepare your laptop for disassembly: étape 1, image 1 de 2 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Prepare your laptop for disassembly: étape 1, image 2 de 2
    • Allow your laptop's battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
    Demander à FixBot
    Ajouter un commentaire
  2. Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Flip the laptop over: étape 2, image 1 de 2 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Flip the laptop over: étape 2, image 2 de 2
    • Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
    Demander à FixBot
  3. Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Feet removal information: étape 3, image 1 de 3 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Feet removal information: étape 3, image 2 de 3 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Feet removal information: étape 3, image 3 de 3
    • Each foot has a recess to help pry it from the laptop:
    • The back feet recesses are closest to the back edge of the laptop.
    • The front feet recesses are closest to the front edge of the laptop.
    Demander à FixBot
  4. Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Remove the feet: étape 4, image 1 de 3 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Remove the feet: étape 4, image 2 de 3 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Remove the feet: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Insert one arm of your tweezers into the recess of one of the feet.
    • Twist your tweezers and pry up to separate the adhesive and unclip the foot from the laptop.
    • The feet eject very quickly—be careful not to lose them.
    • Remove the foot.
    • Repeat this process on the remaining feet.
    Demander à FixBot
  5. Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Reassembly information: étape 5, image 1 de 2 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Reassembly information: étape 5, image 2 de 2
    Tesa 61395 Tape
    $8.95
    • This laptop has two different types of feet. During reassembly, make sure the feet go in their correct recesses.
    • The rear feet have a single center clip.
    • The front feet have three clips and can only be reinserted one way.
    • Press the feet into their recesses to secure them to the frame.
    • If the existing feet no longer adhere to the frame, remove the old adhesive and apply a small amount of Tesa Tape where the old adhesive was.
    Demander à FixBot
  6. Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement: étape 6, image 1 de 3 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement: étape 6, image 2 de 3 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement: étape 6, image 3 de 3
    • If the feet are damaged or worn out, use 8 mm rubber furniture pads:
    • Peel a pad away from its backing.
    • Align the pad over a foot cavity and press down to secure it.
    Demander à FixBot
  7. Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Unfasten the upper case: étape 7, image 1 de 1
    FixMat
    $36.95
    • These screws strip easily. Apply constant, downward force to prevent stripping.
    • Use a T5 Torx driver to remove the four 3 mm screws securing the upper case.
    Demander à FixBot
  8. Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Open the screen: étape 8, image 1 de 3 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Open the screen: étape 8, image 2 de 3 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Open the screen: étape 8, image 3 de 3
    • Flip your laptop over and fully open the screen.
    Demander à FixBot
  9. Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Lift the upper case: étape 9, image 1 de 3 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Lift the upper case: étape 9, image 2 de 3 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Lift the upper case: étape 9, image 3 de 3
    • The upper case is secured by magnets.
    • Grip the top edge of the upper case above the keyboard and lift straight up to release it.
    • Don't try to completely remove the upper case, as it's still connected to the laptop by a cable.
    • Lift the bottom edge of the upper case up and away from the laptop, taking care to not strain the ribbon cable underneath.
    • During reassembly, lower the upper case onto the lower case until the magnets snap into place and it lays flat.
    • Check that the upper case sits flush around the entire perimeter. Any gaps between the upper and lower case near the screen could damage the screen as it closes.
    Demander à FixBot
  10. Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Disconnect the keyboard and touchpad cable: étape 10, image 1 de 3 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Disconnect the keyboard and touchpad cable: étape 10, image 2 de 3 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Disconnect the keyboard and touchpad cable: étape 10, image 3 de 3
    • The keyboard and touchpad cable connects the upper case to the laptop.
    • Insert the pointed end of a spudger under one edge of the magnet connector and pry up to disconnect it.
    • To reconnect the cable, align the magnet connector over its socket with the cable facing the bottom of the laptop. Press down on the connector to secure it.
    Demander à FixBot
  11. Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Remove the upper case: étape 11, image 1 de 1
    • Remove the upper case and set it keyboard-side down on a clean surface.
    Demander à FixBot
  12. Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Unfasten the touchpad cover: étape 12, image 1 de 1
    • Use a T3 Torx driver to remove the eight 1.9 mm screws securing the touchpad cover.
    Demander à FixBot
  13. Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Remove the touchpad cover: étape 13, image 1 de 2 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Remove the touchpad cover: étape 13, image 2 de 2
    • Remove the touchpad cover.
    Demander à FixBot
  14. Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Unclip the touchpad shield: étape 14, image 1 de 3 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Unclip the touchpad shield: étape 14, image 2 de 3 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Unclip the touchpad shield: étape 14, image 3 de 3
    • Insert one arm of your tweezers under the corner of the touchpad shield.
    • Make sure to insert your tweezers between the shield and the frame. Don't pry behind the metal frame.
    • Gently pry up to release the clips securing the shield.
    • Try not to deform the shield too much. You'll need to reinstall it during reassembly.
    • Repeat this process around the perimeter of the shield until you can remove it.
    • To reinstall the shield, orient it correctly and press down around the perimeter to engage the shield clips.
    Demander à FixBot
  15. Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Remove the touchpad shield: étape 15, image 1 de 2 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Remove the touchpad shield: étape 15, image 2 de 2
    • Remove the touchpad shield.
    Demander à FixBot
  16. Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Disconnect the touchpad cables: étape 16, image 1 de 3 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Disconnect the touchpad cables: étape 16, image 2 de 3 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Disconnect the touchpad cables: étape 16, image 3 de 3
    • Use the pointed end of a spudger to lift the locking flaps on the three ZIF connectors on the touchpad.
    Demander à FixBot
  17. Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement: étape 17, image 1 de 3 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement: étape 17, image 2 de 3 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement: étape 17, image 3 de 3
    • Light adhesive secures the two black ribbon cables to the touchpad bracket.
    • Slide one arm of your angled tweezers under the wider ribbon cable and gently lift to separate the adhesive securing it to the touchpad bracket.
    • Repeat for the middle ribbon cable to separate the adhesive.
    Demander à FixBot
  18. Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement: étape 18, image 1 de 3 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement: étape 18, image 2 de 3 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement: étape 18, image 3 de 3
    • Use a pair of tweezers to pull the three cables out of their connectors on the touchpad.
    • When possible, use the attached pull tabs rather than pulling on the actual cables.
    Demander à FixBot
  19. Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement: étape 19, image 1 de 1
    • Remove the keyboard and touchpad cable (the middle ribbon cable) from the upper case and set it aside for reassembly.
    Demander à FixBot
  20. Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Remove the touchpad screws: étape 20, image 1 de 1
    • Use a T5 Torx driver to remove the six 3.1 mm screws securing the touchpad.
    Demander à FixBot
  21. Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Remove the touchpad: étape 21, image 1 de 3 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Remove the touchpad: étape 21, image 2 de 3 Microsoft Surface Laptop 4 (13.5-inch) Touchpad Replacement, Remove the touchpad: étape 21, image 3 de 3
    Demander à FixBot
Clay Eickemeyer
Membre depuis le 09/19/22
105 444 Réputation
472 tutoriels rédigés
Équipe
Guide Team Membre de l'équipe Guide Team
Staff
10 membres
21 380 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 17
30 derniers jours : 89
Total : 3,018
