Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement
Ce dont vous avez besoin
  1. Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Prepare your laptop for disassembly: étape 1, image 1 de 2 Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Prepare your laptop for disassembly: étape 1, image 2 de 2
    • Allow your laptop's battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
    Demander à FixBot
    Ajouter un commentaire
  2. Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Flip the laptop over: étape 2, image 1 de 2 Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Flip the laptop over: étape 2, image 2 de 2
    • Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
    Demander à FixBot
  3. Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Feet removal information: étape 3, image 1 de 3 Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Feet removal information: étape 3, image 2 de 3 Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Feet removal information: étape 3, image 3 de 3
    • Each foot has a recess to help pry it from the laptop:
    • The back feet recesses are closest to the back edge of the laptop.
    • The front feet recesses are closest to the front edge of the laptop.
    Demander à FixBot
  4. Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Remove the feet: étape 4, image 1 de 3 Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Remove the feet: étape 4, image 2 de 3 Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Remove the feet: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Insert one arm of your tweezers into the recess of one of the feet.
    • Twist your tweezers and pry up to separate the adhesive and unclip the foot from the laptop.
    • The feet eject very quickly—be careful not to lose them.
    • Remove the foot.
    • Repeat this process on the remaining feet.
    Demander à FixBot
  5. Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Reassembly information: étape 5, image 1 de 2 Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Reassembly information: étape 5, image 2 de 2
    Tesa 61395 Tape
    $8.95
    • This laptop has two different types of feet. During reassembly, make sure the feet go in their correct recesses.
    • The rear feet have a single center clip.
    • The front feet have three clips and can only be reinserted one way.
    • Press the feet into their recesses to secure them to the frame.
    • If the existing feet no longer adhere to the frame, remove the old adhesive and apply a small amount of Tesa Tape where the old adhesive was.
    Demander à FixBot
  6. Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement: étape 6, image 1 de 3 Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement: étape 6, image 2 de 3 Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement: étape 6, image 3 de 3
    • If the feet are damaged or worn out, use 8 mm rubber furniture pads:
    • Peel a pad away from its backing.
    • Align the pad over a foot cavity and press down to secure it.
    Demander à FixBot
  7. Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Unfasten the upper case: étape 7, image 1 de 1
    FixMat
    $36.95
    • These screws strip easily. Apply constant, downward force to prevent stripping.
    • Use a T5 Torx driver to remove the four 3 mm screws securing the upper case.
    Demander à FixBot
  8. Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Open the screen: étape 8, image 1 de 3 Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Open the screen: étape 8, image 2 de 3 Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Open the screen: étape 8, image 3 de 3
    • Flip your laptop over and fully open the screen.
    Demander à FixBot
  9. Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Lift the upper case: étape 9, image 1 de 3 Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Lift the upper case: étape 9, image 2 de 3 Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Lift the upper case: étape 9, image 3 de 3
    • The upper case is secured by magnets.
    • Grip the top edge of the upper case above the keyboard and lift straight up to release it.
    • Don't try to completely remove the upper case, as it's still connected to the laptop by a cable.
    • Lift the bottom edge of the upper case up and away from the laptop, taking care to not strain the ribbon cable underneath.
    • During reassembly, lower the upper case onto the lower case until the magnets snap into place and it lays flat.
    • Check that the upper case sits flush around the entire perimeter. Any gaps between the upper and lower case near the screen could damage the screen as it closes.
    Demander à FixBot
  10. Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Disconnect the keyboard and touchpad cable: étape 10, image 1 de 3 Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Disconnect the keyboard and touchpad cable: étape 10, image 2 de 3 Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Disconnect the keyboard and touchpad cable: étape 10, image 3 de 3
    • The keyboard and touchpad cable connects the upper case to the laptop.
    • Insert the pointed end of a spudger under one edge of the magnet connector and pry up to disconnect it.
    • To reconnect the cable, align the magnet connector over its socket with the cable facing the bottom of the laptop. Press down on the connector to secure it.
    Demander à FixBot
  11. Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Remove the upper case: étape 11, image 1 de 1
    • Remove the upper case and set it keyboard-side down on a clean surface.
    Demander à FixBot
  12. Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Unfasten the SSD: étape 12, image 1 de 1
    • Use a T5 Torx driver to remove the 2.7 mm screw securing the SSD.
    • With the screw removed, the SSD pops up at a shallow angle.
    Demander à FixBot
  13. Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Remove the SSD: étape 13, image 1 de 2 Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Remove the SSD: étape 13, image 2 de 2
    • Removing the SSD also functions as a battery disconnect.
    • Pull the SSD out of its socket and remove it.
    • Don't pull up at a sharp angle, as this could damage the SSD and its socket.
    • During reassembly, insert the SSD at a slight angle.
    Demander à FixBot
  14. Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Disconnect the port connector: étape 14, image 1 de 3 Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Disconnect the port connector: étape 14, image 2 de 3 Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Disconnect the port connector: étape 14, image 3 de 3
    • Use the flat end of spudger to flip open the gold locking arm on the Surface Connect port motherboard connector.
    • Hold the tape out of the way, if necessary.
    • Grip the Surface Connect port cable and pull it away from its connector to disconnect it.
    Demander à FixBot
  15. Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Unfasten the port cover: étape 15, image 1 de 1
    • Use a T3 Torx driver to remove the four screws securing the Surface Connect port cover:
    • Two 2.0 mm screws
    • Two 2.2 mm screws
    Demander à FixBot
  16. Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Remove the port cover: étape 16, image 1 de 2 Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Remove the port cover: étape 16, image 2 de 2
    • Remove the Surface Connect port cover.
    Demander à FixBot
  17. Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Unfasten the port: étape 17, image 1 de 1
    • Use a T3 Torx driver to remove the two 3 mm screws securing the Surface Connect port.
    Demander à FixBot
  18. Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Remove the port: étape 18, image 1 de 3 Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Remove the port: étape 18, image 2 de 3 Microsoft Surface Laptop 4 (15-inch) Surface Connect Port Replacement, Remove the port: étape 18, image 3 de 3
    • Pull the Surface Connect port away from the edge of the chassis and remove it.
    Demander à FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting or check out our Answers community for help.
Spencer Day
Membre depuis le 09/14/22
196 112 Réputation
1 243 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
27 624 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 33
Total : 1,050
