Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement
Ce dont vous avez besoin
    1. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Prepare your laptop for disassembly: étape 1, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Prepare your laptop for disassembly: étape 1, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Prepare your laptop for disassembly: étape 1, image 3 de 3
      • Before starting this repair, allow your laptop's battery to drain below 25%. A charged battery may catch fire if damaged.
      • Unplug all cables and fully shut down your laptop.
      Demander à FixBot
      Ajouter un commentaire
    1. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Flip your laptop over: étape 2, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Flip your laptop over: étape 2, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Flip your laptop over: étape 2, image 3 de 3
      • Close your laptop and lay it down so the rubber feet are facing up.
      Demander à FixBot
    2. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Remove the feet: étape 3, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Remove the feet: étape 3, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Remove the feet: étape 3, image 3 de 3
      • Gently slide one arm of your angled tweezers into the recess near the upper right edge of one of the feet.
      • You can also use the point of a spudger. However, you're more likely to damage the foot, if you're reusing it.
      • Use your tweezers to pry up and remove the foot.
      • The feet may eject very quickly—be careful not to lose them.
      • Repeat the process to remove the remaining feet.
      • To install a foot, align the pegs on the bottom with their cutouts in the frame and press the foot into place.
      Demander à FixBot
    1. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Remove the lower case screws: étape 4, image 1 de 2 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Remove the lower case screws: étape 4, image 2 de 2
      Outil utilisé dans cette étape :
      FixMat
      $36.95
      • While the Surface Laptop 7 uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
      • Use a Torx Plus 5IP screwdriver to remove the four 4.5 mm‑long screws (with washers) securing the lower case.
      Demander à FixBot
    2. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Detach the lower case: étape 5, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Detach the lower case: étape 5, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Detach the lower case: étape 5, image 3 de 3
      • Insert the tip of an opening pick under the top edge of the lower case, about an inch (2.5 cm) to the left or right of the Microsoft logo.
      • Don't insert the pick near the outer edges or you'll damage the antenna bar.
      Demander à FixBot
    3. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: étape 6, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: étape 6, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: étape 6, image 3 de 3
      • Twist the pick to lift the lower case enough that you can grip it with your hand.
      Demander à FixBot
    4. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Remove the lower case: étape 7, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Remove the lower case: étape 7, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Remove the lower case: étape 7, image 3 de 3
      • Lift the lower case and remove it.
      Demander à FixBot
    1. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Disconnect the battery: étape 8, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Disconnect the battery: étape 8, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Disconnect the battery: étape 8, image 3 de 3
      • Use a Torx Plus 3IP screwdriver to remove the two 2.3 mm‑long screws securing the battery connector cover.
      Demander à FixBot
    2. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: étape 9, image 1 de 2 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: étape 9, image 2 de 2
      • Use tweezers or your fingers to remove the battery connector cover.
      Demander à FixBot
    3. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: étape 10, image 1 de 2 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: étape 10, image 2 de 2
      • Insert the flat end of a spudger under the top edge of the battery press connector and pry up to disconnect it.
      • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It may take a few tries to align the connector—don't try to force it into place.
      Demander à FixBot
    1. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Peel up the SSD tape: étape 11, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Peel up the SSD tape: étape 11, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Peel up the SSD tape: étape 11, image 3 de 3
      • Heat an iOpener and lay it on the SSD for one minute to heat the tape on its left edge.
      • Alternatively, you can use a hair dryer to lightly heat the tape.
      Demander à FixBot
    2. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: étape 12, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: étape 12, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: étape 12, image 3 de 3
      • Carefully insert the point of a spudger under the SSD tape and lift until you can grip the tape with your fingers.
      • Be careful not to tear the tape, since you'll reuse it during reassembly.
      • Use your fingers to gently peel the tape from the SSD.
      • You don't need to fully remove the tape, it just needs to be off the SSD.
      Demander à FixBot
    3. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Remove the SSD: étape 13, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Remove the SSD: étape 13, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Remove the SSD: étape 13, image 3 de 3
      • Use a Torx Plus 5IP screwdriver to remove the 2.9 mm‑long screw securing the SSD.
      • With the screw removed, the SSD may pop up at a slight angle.
      • During reassembly, gently hold the SSD down while installing its screw.
      Demander à FixBot
    4. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: étape 14, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: étape 14, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: étape 14, image 3 de 3
      • Grip the SSD by its edges near the screw notch and pull it straight out of its socket.
      • During reassembly, make sure the tape is completely out of the way and insert the SSD at a slight downward angle into its socket.
      • The SSD is notched so you can only insert it in the correct orientation.
      Demander à FixBot
Once your laptop is reassembled, follow Microsoft's post SSD replacement guide.
5 autres ont terminé cette réparation.
Spencer Day
Membre depuis le 09/14/22
206 456 Réputation
1 266 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
121 membres
72 737 tutoriels rédigés
5 commentaires de tutoriel
only the original SSD can be replaced? other manufacturers won't work?
Александр - Réponse Partager
Any other SSD will work. I replaced mine with a 1tb drive after I cloned the original. Reinstalled and it was like nothing happened. No need to update windows or anything. I used DiskGenius but use whatever safe program you prefer.
Jonathan Sikes - Réponse Partager
Is there a need to remove the battery?
Stevenson Yu - Réponse Partager
Hello! You don't need to remove the battery, just disconnect it to avoid damaging your laptop.
Nick Schultz - Réponse Partager
also. this needs to say it needs DISM to backup drivers first
coshvji cujmlqef - Réponse Partager
Nombre de vues :
Dernières 24 heures : 20
7 derniers jours : 116
30 derniers jours : 518
Total : 16,004
