Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Microsoft Surface Pro Kickstand Replacement
Ce dont vous avez besoin
    1. Microsoft Surface Pro Kickstand Replacement, Kickstand: étape 1, image 1 de 1
      • Turn the tablet so the back is facing up.
      • Lift the kickstand to access the screws.
      • Remove the two T5 Torx screws:
      • One from the left hinge
      • One from the right hinge
      Demander à FixBot
      Ajouter un commentaire
    2. Microsoft Surface Pro Kickstand Replacement: étape 2, image 1 de 1
      • To remove the kickstand, gently pull up until the three tabs slide out of the slots on the back of the device.
      Demander à FixBot
12 autres ont terminé cette réparation.
Mark
Membre depuis le 10/09/13
764 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 8-20, Regan Fall 2013 Membre de l'équipe Cal Poly, Team 8-20, Regan Fall 2013
CPSU-REGAN-F13S8G20
4 membres
16 tutoriels rédigés
1 commentaire de tutoriel
I had trouble getting the center tab to slide out of the slot. After looking at the other tabs, which came out easily, I noticed that the tabs are not composed of a single piece but are actually two sheets glued together (like two pieces of tape). Somehow the two pieces of tape composing the center tab had come apart, exposing their adhesive surfaces, and sticking to an inner surface. I managed to push them apart enough from the outside with a flathead screwdriver so that I could slide the center tab out. However, the other piece is stuck inside the device.
artlives13 - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 58
30 derniers jours : 142
Total : 41,172
