Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Modal MD-WORCSS6 LED Replacement
Ce dont vous avez besoin
  1. Modal MD-WORCSS6 LED Replacement, Modal MD-WORCSS6 Teardown Guide: étape 1, image 1 de 2 Modal MD-WORCSS6 LED Replacement, Modal MD-WORCSS6 Teardown Guide: étape 1, image 2 de 2
    • Put on Electrostatic Discharge (ESD) bracelet. Hold the device with the transparent plastic casing on the top.
    • Using the jimmy tool, carefully pry off the black plastic ring.
    • Remove the spring assembly from inside the transparent plastic tube.
    Demander à FixBot
    Ajouter un commentaire
  2. Modal MD-WORCSS6 LED Replacement: étape 2, image 1 de 2 Modal MD-WORCSS6 LED Replacement: étape 2, image 2 de 2
    • Using a Phillips #1 screwdriver, unscrew each of the four 12.7 mm screws inside and at the bottom of the plastic tube.
    • Take the plastic tube off of the metal casing.
    Demander à FixBot
  3. Modal MD-WORCSS6 LED Replacement: étape 3, image 1 de 2 Modal MD-WORCSS6 LED Replacement: étape 3, image 2 de 2
    • Place the jimmy tool blade between the button assembly and the metal casing. Gently pry off the button assembly; it should pop out.
    • With the button assembly removed, slide off the metal casing.
    Demander à FixBot
  4. Modal MD-WORCSS6 LED Replacement: étape 4, image 1 de 3 Modal MD-WORCSS6 LED Replacement: étape 4, image 2 de 3 Modal MD-WORCSS6 LED Replacement: étape 4, image 3 de 3
    • Unscrew the two 6.4 mm screws in the black plastic body using the Phillips #1 screwdriver.
    • Separate the two halves of the plastic body. Keep the half containing the motor facing up.
    Demander à FixBot
  5. Modal MD-WORCSS6 LED Replacement: étape 5, image 1 de 3 Modal MD-WORCSS6 LED Replacement: étape 5, image 2 de 3 Modal MD-WORCSS6 LED Replacement: étape 5, image 3 de 3
    • Carefully peel the tape off far enough to remove the 3 batteries.
    Demander à FixBot
  6. Modal MD-WORCSS6 LED Replacement, LED: étape 6, image 1 de 3 Modal MD-WORCSS6 LED Replacement, LED: étape 6, image 2 de 3 Modal MD-WORCSS6 LED Replacement, LED: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    • Slide the circuit board out of its slot.
    • Remove the LEDs by clipping off their connections with a pair of tweezers.
    • Attach the new LEDs by soldering the ends of the LEDS to their corresponding connections on the circuit board.
    • Check out our How to Solder and Desolder Connections guide for best practices and soldering tips.
    Demander à FixBot
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 23
Total : 287
