Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Monster DNA Wire Replacement
Ce dont vous avez besoin
    1. Monster DNA Wire Replacement, Wire: étape 1, image 1 de 1
      • Take off the ear cushions by pulling on the sides.
      Demander à FixBot
      Ajouter un commentaire
    2. Monster DNA Wire Replacement: étape 2, image 1 de 1
      • Use a Phillips #2 screwdriver to unscrew the three 5mm screws that secure the speaker cover.
      Demander à FixBot
    3. Monster DNA Wire Replacement: étape 3, image 1 de 1
      • Use a plastic opening tool or a metal spudger to pry off the plate
      • Be careful as too much force may cause damage to your headphones.
      Demander à FixBot
    4. Monster DNA Wire Replacement: étape 4, image 1 de 1
      • Once the loose wire or wires are located on the back of the speaker, use a soldering iron to attach the loose wire back onto the speaker.
      Demander à FixBot
Kevin Costello
Membre depuis le 03/22/17
231 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S4-G5, Julie Spring 2017 Membre de l'équipe UMass Dartmouth, Team S4-G5, Julie Spring 2017
UMASSD-JULIE-S17S4G5
4 membres
12 tutoriels rédigés
2 commentaires de tutoriel
any ways on being able to know which side its on in particular without having to open both sides?
Finnlay Worchurst - Réponse Partager
I broke the plate which holds the ear muffs on, by following these directions.
On Step 3, you have the spudger in the wrong location. You are supposed to put the prying bar or spudger before or after the silver ring which acts as a spacer for the speaker housing. I like to pry in the space between the silver ring and the audio jack.
Pics look good but you will have replace the one in step 3 showing the correct location to pry from. Others too will brake the same ring I did hence your warning about damage to the headphones if applying too much pressure.
Dan
Dan Daley - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 50
Total : 4,448
