Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Motion Computing LE1600 Button Assembly Replacement
Ce dont vous avez besoin
  1. Motion Computing LE1600 Button Assembly Replacement, Battery: étape 1, image 1 de 1
    • Turn the device so the screen is facing down.
    Demander à FixBot
    Ajouter un commentaire
  2. Motion Computing LE1600 Button Assembly Replacement: étape 2, image 1 de 2 Motion Computing LE1600 Button Assembly Replacement: étape 2, image 2 de 2
    • Slide the battery lock switch next to the power slider to the unlocked position.
    Demander à FixBot
  3. Motion Computing LE1600 Button Assembly Replacement: étape 3, image 1 de 3 Motion Computing LE1600 Button Assembly Replacement: étape 3, image 2 de 3 Motion Computing LE1600 Button Assembly Replacement: étape 3, image 3 de 3
    • Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
    • When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
    Demander à FixBot
  4. Motion Computing LE1600 Button Assembly Replacement, Button Assembly: étape 4, image 1 de 1
    • Unscrew hard drive panel using a Phillips head #1 screwdriver.
    • (Our device was not given to us with a hard drive or a hard drive panel)
    Demander à FixBot
  5. Motion Computing LE1600 Button Assembly Replacement: étape 5, image 1 de 3 Motion Computing LE1600 Button Assembly Replacement: étape 5, image 2 de 3 Motion Computing LE1600 Button Assembly Replacement: étape 5, image 3 de 3
    • Pull clear plastic tab to detach hard drive from tablet.
    Demander à FixBot
  6. Motion Computing LE1600 Button Assembly Replacement: étape 6, image 1 de 2 Motion Computing LE1600 Button Assembly Replacement: étape 6, image 2 de 2
    • To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs.
    Demander à FixBot
  7. Motion Computing LE1600 Button Assembly Replacement: étape 7, image 1 de 1
    • Pull the brown tabs to disconnect the white ribbon cable on the other side.
    Demander à FixBot
  8. Motion Computing LE1600 Button Assembly Replacement: étape 8, image 1 de 2 Motion Computing LE1600 Button Assembly Replacement: étape 8, image 2 de 2
    • Caution: do not pull on the wires, instead pull from the plastic connectors.
    • To disconnect the remaining ribbon cables, pull the plastic connectors away from their connections.
    Demander à FixBot
  9. Motion Computing LE1600 Button Assembly Replacement: étape 9, image 1 de 1
    • With a Phillips #1 screwdriver, Unscrew the nine 10mm screws holding the case together.
    Demander à FixBot
  10. Motion Computing LE1600 Button Assembly Replacement: étape 10, image 1 de 2 Motion Computing LE1600 Button Assembly Replacement: étape 10, image 2 de 2
    • Using a spudger, press in the five tabs on the side where the battery was.
    • This should separate the two halves of the device. Carefully set the side with the motherboard off to the side.
    Demander à FixBot
  11. Motion Computing LE1600 Button Assembly Replacement: étape 11, image 1 de 2 Motion Computing LE1600 Button Assembly Replacement: étape 11, image 2 de 2
    • Unplug the three ribbon cables by pulling on the brown tabs and unplugging cable.
    Demander à FixBot
  12. Motion Computing LE1600 Button Assembly Replacement: étape 12, image 1 de 2 Motion Computing LE1600 Button Assembly Replacement: étape 12, image 2 de 2
    • With a Phillips #1 screwdriver, unscrew the three 4mm screws holding the display bracket on the back side of the front buttons.
    Demander à FixBot
  13. Motion Computing LE1600 Button Assembly Replacement: étape 13, image 1 de 2 Motion Computing LE1600 Button Assembly Replacement: étape 13, image 2 de 2
    • Remove the button board and replace.
    Demander à FixBot
Fred Wilby
Membre depuis le 04/03/12
71 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 15-14, Forte Spring 2012 Membre de l'équipe Cal Poly, Team 15-14, Forte Spring 2012
CPSU-FORTE-S12S15G14
5 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 46
Total : 2,355
