Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Motorola C290 Keypad Replacement
Ce dont vous avez besoin
  1. Motorola C290 Keypad Replacement, Battery: étape 1, image 1 de 2 Motorola C290 Keypad Replacement, Battery: étape 1, image 2 de 2
    • Position Motorola C290 so that the back of the phone is facing up.
    • Apply pressure to the back cover while simultaneously sliding it downwards.
    • Note: It may be easiest to apply pressure to the ridges at the top of the back cover.
    Demander à FixBot
    Ajouter un commentaire
  2. Motorola C290 Keypad Replacement: étape 2, image 1 de 2 Motorola C290 Keypad Replacement: étape 2, image 2 de 2
    • Place your finger in the notch at the top of the battery.
    • Gently lift and pull out battery.
    Demander à FixBot
  3. Motorola C290 Keypad Replacement, Antenna: étape 3, image 1 de 3 Motorola C290 Keypad Replacement, Antenna: étape 3, image 2 de 3 Motorola C290 Keypad Replacement, Antenna: étape 3, image 3 de 3
    • Unscrew antenna head from top of phone by twisting counterclockwise.
    • Pull the antenna out through the top hole and set aside.
    Demander à FixBot
  4. Motorola C290 Keypad Replacement: étape 4, image 1 de 2 Motorola C290 Keypad Replacement: étape 4, image 2 de 2
    • Remove the plastic tube by lifting the bottom and pulling out towards yourself.
    Demander à FixBot
  5. Motorola C290 Keypad Replacement, Logic Board: étape 5, image 1 de 3 Motorola C290 Keypad Replacement, Logic Board: étape 5, image 2 de 3 Motorola C290 Keypad Replacement, Logic Board: étape 5, image 3 de 3
    • Insert a Spudger (or pushpin) into the top notch of the rubber cover, located on the top of the phone.
    • Press down and rotate the Spudger lifting the rubber cover. Remove and set cover aside.
    • Note: This will reveal a screw. Five screws should now be visible.
    • Using a T6 Torx screwdriver, unscrew all 5 screws and carefully set them aside.
    Demander à FixBot
  6. Motorola C290 Keypad Replacement: étape 6, image 1 de 2 Motorola C290 Keypad Replacement: étape 6, image 2 de 2
    • Insert the plastic opening tool in the groove at the top of the phone.
    • Rotate the tool to create an opening between the logic board cover and case.
    Demander à FixBot
  7. Motorola C290 Keypad Replacement: étape 7, image 1 de 2 Motorola C290 Keypad Replacement: étape 7, image 2 de 2
    • Slide the plastic opening tool along the groove, until the entire logic board cover has been opened.
    • Remove logic board cover and set aside.
    Demander à FixBot
  8. Motorola C290 Keypad Replacement: étape 8, image 1 de 1
    • Use the Spudger to detach the screen wire from the logic board.
    Demander à FixBot
  9. Motorola C290 Keypad Replacement: étape 9, image 1 de 3 Motorola C290 Keypad Replacement: étape 9, image 2 de 3 Motorola C290 Keypad Replacement: étape 9, image 3 de 3
    • Insert the Spudger into the slot on the top of the logic board.
    • Gently pry to loosen the top of the logic board.
    • Note: The logic board may initially seem glued to the phone. It is not glued but does require input of force to remove.
    • Grab the top of the logic board and pull at an angle to remove.
    Demander à FixBot
  10. Motorola C290 Keypad Replacement, Keypad: étape 10, image 1 de 1
    • Use your fingers to pull out the keypad.
    • Note: The keys and rubber backing are one piece.
    Demander à FixBot
Angelo Ballungay
Membre depuis le 04/15/10
79 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 24-28, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 24-28, Regan Spring 2010
CPSU-REGAN-S10S24G28
4 membres
16 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 6
30 derniers jours : 29
Total : 1,453
