Introduction
Use this guide to remove and replace the screen assembly including the frame of the Motorola Moto E4 Plus.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
While this guide is written with the XT1771 model, you can also use this guide for other Moto E4 Plus variants, such as XT1772, and XT1773.
Before disassembling your phone, discharge the battery below 25%. If your battery is swollen, do not heat your phone. Swollen batteries can be very dangerous, so wear eye protection and exercise due caution, or take it to a professional if you're not sure how to proceed.
You’ll need replacement adhesive to reattach components when reassembling the device.
Ce dont vous avez besoin
Insert the edge of the spudger into the notch on the bottom right corner of the phone.
Twist the spudger to start releasing the back cover from the phone.
Slide the spudger along the bottom edge to separate the back cover from the phone.
Remove the eighteen 3.3 mm Phillips screws securing the midframe assembly.
Use the edge of a spudger to pry up and disconnect the battery flex cable from the motherboard.
Apply a heated iOpener to the upper part of the phone for about 30 seconds to loosen the adhesive beneath the earpiece speaker.
3 autres ont terminé cette réparation.
2 commentaires
Bonjour cher ami
Grace a vous je me suis lancé dans le remplacement de mon ecran explosé par le passage d’un véhicule. j’ai suivi vos explications a la lettre dans le démontage et pour le remontage aussi vous n’avez pas signalé de récupérer le revêtement de cuivre, j’ai réussi de le décoller en chauffant. Tout fonctionne comme avant.
Merci de ce tuto. Félicitations.
Thanks for your comment. Glad to hear you could get it back to working conditions. Welcome to the club of fixers.
