Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Motorola SLVR L9 Keypad Replacement
Ce dont vous avez besoin
  1. Motorola SLVR L9 Keypad Replacement, Battery: étape 1, image 1 de 2 Motorola SLVR L9 Keypad Replacement, Battery: étape 1, image 2 de 2
    • Turn the phone over so that the back of the phone is facing up.
    Demander à FixBot
    Ajouter un commentaire
  2. Motorola SLVR L9 Keypad Replacement: étape 2, image 1 de 3 Motorola SLVR L9 Keypad Replacement: étape 2, image 2 de 3 Motorola SLVR L9 Keypad Replacement: étape 2, image 3 de 3
    • Press down on the silver battery cover latch located at the top of the phone.
    • Pull the battery cover down and away from the latch; then lift it up to remove the battery cover.
    Demander à FixBot
  3. Motorola SLVR L9 Keypad Replacement: étape 3, image 1 de 3 Motorola SLVR L9 Keypad Replacement: étape 3, image 2 de 3 Motorola SLVR L9 Keypad Replacement: étape 3, image 3 de 3
    • To remove the battery, pull the battery up from the bottom center.
    Demander à FixBot
  4. Motorola SLVR L9 Keypad Replacement, Camera Lens Cover: étape 4, image 1 de 2 Motorola SLVR L9 Keypad Replacement, Camera Lens Cover: étape 4, image 2 de 2
    • Turn the phone over so that the back of the phone is facing towards you.
    Demander à FixBot
  5. Motorola SLVR L9 Keypad Replacement: étape 5, image 1 de 3 Motorola SLVR L9 Keypad Replacement: étape 5, image 2 de 3 Motorola SLVR L9 Keypad Replacement: étape 5, image 3 de 3
    • Press down on the battery cover latch located at the top of the phone.
    Demander à FixBot
  6. Motorola SLVR L9 Keypad Replacement: étape 6, image 1 de 1
    • Remove the four housing screws (1/8") from each corner of the transceiver PC board shield. Use a screwdriver with a T6 Torx screwdriver head to turn the screws counter-clockwise (left).
    Demander à FixBot
  7. Motorola SLVR L9 Keypad Replacement: étape 7, image 1 de 2 Motorola SLVR L9 Keypad Replacement: étape 7, image 2 de 2
    • Once you have removed all of the screws, lift the transceiver PC board shield up to remove it.
    Demander à FixBot
  8. Motorola SLVR L9 Keypad Replacement, Antenna Cover: étape 8, image 1 de 3 Motorola SLVR L9 Keypad Replacement, Antenna Cover: étape 8, image 2 de 3 Motorola SLVR L9 Keypad Replacement, Antenna Cover: étape 8, image 3 de 3
    • Use the plastic opening tool to loosen the cover latch.
    • Once the cover latch has been loosened, gently pull the cover latch off of the device.
    Demander à FixBot
  9. Motorola SLVR L9 Keypad Replacement, Keypad: étape 9, image 1 de 1
    • Use a screwdriver with a T6 Torx screwdriver head to remove both screws (1/8") from the speaker housing. Turn the screw counter-clockwise (left).
    Demander à FixBot
  10. Motorola SLVR L9 Keypad Replacement: étape 10, image 1 de 3 Motorola SLVR L9 Keypad Replacement: étape 10, image 2 de 3 Motorola SLVR L9 Keypad Replacement: étape 10, image 3 de 3
    • Using the grooves around the edge of the phone, gently pull the front plate away from the phone until it is fully removed from the device.
    Demander à FixBot
  11. Motorola SLVR L9 Keypad Replacement: étape 11, image 1 de 2 Motorola SLVR L9 Keypad Replacement: étape 11, image 2 de 2
    • Lift the keypad up from the front plate to remove.
    Demander à FixBot
Eric Lopez
Membre depuis le 10/13/15
201 Réputation
2 tutoriels rédigés
Équipe
Sam Houston State, Team 1-5, Blackburne Fall 2015 Membre de l'équipe Sam Houston State, Team 1-5, Blackburne Fall 2015
SHSU-BLACKBURNE-F15S1G5
3 membres
15 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 19
Total : 594
