Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre NBC Kentucky Derby Brooch, utilisez notre manuel de réparation.
  1. NBC Kentucky Derby  Brooch Teardown, Assemble Horse: étape 1, image 1 de 3 NBC Kentucky Derby  Brooch Teardown, Assemble Horse: étape 1, image 2 de 3 NBC Kentucky Derby  Brooch Teardown, Assemble Horse: étape 1, image 3 de 3
    • Gather all components and flip everything over.
    • Mount the head, tail, and both legs by placing them over their pivot points.
  2. NBC Kentucky Derby  Brooch Teardown, Attach linkage: étape 2, image 1 de 3 NBC Kentucky Derby  Brooch Teardown, Attach linkage: étape 2, image 2 de 3 NBC Kentucky Derby  Brooch Teardown, Attach linkage: étape 2, image 3 de 3
    • Carefully align the linkage with the mounting holes on both legs.
    • Place two 3mm eyeglass screws into either end of the linkage.
    • Tighten the screws. These screws will self-tap into the legs. Be careful to not over-tighten and seize the linkage.
  3. NBC Kentucky Derby  Brooch Teardown, Mount servo: étape 3, image 1 de 3 NBC Kentucky Derby  Brooch Teardown, Mount servo: étape 3, image 2 de 3 NBC Kentucky Derby  Brooch Teardown, Mount servo: étape 3, image 3 de 3
    • Pull the servo through the donut hole of the PCB (top to bottom).
    • Orient the servo arm to the left (aligned with the rest of the body). This represents the zero degree location.
    • Manually move the servo arm down 90 degrees so it is now points downward into the work surface.
    • Mount the servo to the enclosure.
  4. NBC Kentucky Derby  Brooch Teardown, Assemble enclosure: étape 4, image 1 de 3 NBC Kentucky Derby  Brooch Teardown, Assemble enclosure: étape 4, image 2 de 3 NBC Kentucky Derby  Brooch Teardown, Assemble enclosure: étape 4, image 3 de 3
    • Place the PCB overtop the servo.
    • Route the servo's wire around various components as depicted.
    • Coil extra wire in available space.
  5. NBC Kentucky Derby  Brooch Teardown, Mount horse to enclosure: étape 5, image 1 de 3 NBC Kentucky Derby  Brooch Teardown, Mount horse to enclosure: étape 5, image 2 de 3 NBC Kentucky Derby  Brooch Teardown, Mount horse to enclosure: étape 5, image 3 de 3
    • Align the enclosure with the mounting holes on the backside of the horse's body.
    • Align servo arm with the drive gap in the linkage. Double check this correct before tightening.
    • Use two M2 screws to attach the horse to the enclosure.
  6. NBC Kentucky Derby  Brooch Teardown, Assemble back of enclosure: étape 6, image 1 de 3 NBC Kentucky Derby  Brooch Teardown, Assemble back of enclosure: étape 6, image 2 de 3 NBC Kentucky Derby  Brooch Teardown, Assemble back of enclosure: étape 6, image 3 de 3
    • Start by placing the bottom notched-side into the lip of the enclosure.
    • Align all three mounting holes from above.
    • Press firmly with both hands (avoid putting pressure on horse) and work your hands around the edges until the back is pressed flush.
    • Secure the back of the enclosure by driving three M2 screws into place. DO NOT OVER TIGHTEN!
  7. NBC Kentucky Derby  Brooch Teardown, Give it power: étape 7, image 1 de 2 NBC Kentucky Derby  Brooch Teardown, Give it power: étape 7, image 2 de 2
    • Attach wiring harness to brooch.
    • Plug wiring harness into USB power supply.
Justin Sinichko
Membre depuis le 05/01/18
165 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 13
Total : 983
