Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Nerf N-Strike Elite Retaliator Trigger Spring Replacement
Ce dont vous avez besoin
    1. Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Case Disassembly: étape 1, image 1 de 1
      • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
      Demander à FixBot
      Ajouter un commentaire
    2. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: étape 2, image 1 de 1
      • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
      Demander à FixBot
    3. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: étape 3, image 1 de 1
      • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
      Demander à FixBot
    4. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: étape 4, image 1 de 2 Nerf N-Strike Elite Retaliator Trigger Spring Replacement: étape 4, image 2 de 2
      • Remove the stock attachment point by removing the two 8mm Phillips head screws.
      Demander à FixBot
    5. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: étape 5, image 1 de 2 Nerf N-Strike Elite Retaliator Trigger Spring Replacement: étape 5, image 2 de 2
      • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
      • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
      • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
      Demander à FixBot
    1. Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: étape 6, image 1 de 3 Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: étape 6, image 2 de 3 Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: étape 6, image 3 de 3
      • Carefully pull the orange trigger upward and backward to remove it from the blaster.
      • This component is under spring pressure. Wear appropriate personal protective equipment to shield your eyes.
      • Remove the spring from the rear of the trigger.
      Demander à FixBot
ericharman
Membre depuis le 03/02/16
1 440 Réputation
5 tutoriels rédigés
1 commentaire de tutoriel
ok, taken the spring out. now what?
Kelvin Mead - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 37
Total : 10,149
