Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Nerf N-Strike Firestrike LED Replacement
Ce dont vous avez besoin
    1. Nerf N-Strike Firestrike LED Replacement, Blaster Casing: étape 1, image 1 de 1
      • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
      Demander à FixBot
      Ajouter un commentaire
    2. Nerf N-Strike Firestrike LED Replacement: étape 2, image 1 de 2 Nerf N-Strike Firestrike LED Replacement: étape 2, image 2 de 2
      • Slowly pull apart the blaster casing, starting at the battery location.
      • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
      Demander à FixBot
    3. Nerf N-Strike Firestrike LED Replacement: étape 3, image 1 de 2 Nerf N-Strike Firestrike LED Replacement: étape 3, image 2 de 2
      • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
      • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
      • For reassembly, note the location of the springs as highlighted in the second photo.
      Demander à FixBot
    1. Nerf N-Strike Firestrike LED Replacement, Remove battery cover: étape 4, image 1 de 1
      • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
      Demander à FixBot
    2. Nerf N-Strike Firestrike LED Replacement: étape 5, image 1 de 2 Nerf N-Strike Firestrike LED Replacement: étape 5, image 2 de 2
      • Slide out the two AAA batteries using your fingers.
      Demander à FixBot
    1. Nerf N-Strike Firestrike LED Replacement, Laser Trigger: étape 6, image 1 de 2 Nerf N-Strike Firestrike LED Replacement, Laser Trigger: étape 6, image 2 de 2
      • Remove the laser trigger by grabbing the trigger with your fingers and pulling it up and out.
      Demander à FixBot
    1. Nerf N-Strike Firestrike LED Replacement, Laser Assembly: étape 7, image 1 de 1
      • Gently pull up on the circuit board located near the gun handle until it separates from the gun.
      • The wire that attaches to the circuit board is also attached to the laser. Be careful not to use excessive force and damage or disconnect the wire.
      Demander à FixBot
    2. Nerf N-Strike Firestrike LED Replacement: étape 8, image 1 de 3 Nerf N-Strike Firestrike LED Replacement: étape 8, image 2 de 3 Nerf N-Strike Firestrike LED Replacement: étape 8, image 3 de 3
      • Grip the circuit board located at the base of the laser with your fingers; rotate it towards the ammo compartment on the blaster until the guide hole is clear of the guide pin.
      • Slide the laser assembly out.
      Demander à FixBot
    1. Nerf N-Strike Firestrike LED Replacement, LED: étape 9, image 1 de 2 Nerf N-Strike Firestrike LED Replacement, LED: étape 9, image 2 de 2
      • Pinch the clips holding the laser beam casing to the circuit board with your fingers. Slide off the casing revealing the LED.
      Demander à FixBot
    2. Nerf N-Strike Firestrike LED Replacement: étape 10, image 1 de 1
      • Use a soldering iron to heat up the two connections holding the LED to the circuit board. Remove the LED.
      Demander à FixBot
6 autres ont terminé cette réparation.
Hayes Kimball
Membre depuis le 04/19/15
742 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 15-6, Amido Spring 2015 Membre de l'équipe Cal Poly, Team 15-6, Amido Spring 2015
CPSU-AMIDO-S15S15G6
3 membres
8 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 36
Total : 3,594
