Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Nerf Recon CS-6 Main Spring Replacement
Ce dont vous avez besoin
    1. Nerf Recon CS-6 Main Spring Replacement, Remove Magazine: étape 1, image 1 de 1
      • Skip this step if magazine is already removed.
      • Pull slide back.
      • Pull backwards on release buttons and slide magazine out.
      • Push slide back forward and pull trigger.
      Demander à FixBot
      Ajouter un commentaire
    2. Nerf Recon CS-6 Main Spring Replacement, Remove Visible Screws: étape 2, image 1 de 1
      • Use the Phillips #0 Screwdriver to remove these 9 screws.
      • All screws marked in red are 9.6 mm Phillips #0 screws.
      • Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
      Demander à FixBot
    3. Nerf Recon CS-6 Main Spring Replacement, Remove Hidden Screws: étape 3, image 1 de 2 Nerf Recon CS-6 Main Spring Replacement, Remove Hidden Screws: étape 3, image 2 de 2
      • Pull slide back to reveal more screws.
      • Remove these 2 screws.
      • Push slide forward.
      • Pull trigger to release compression of the main spring.
      • Screws are 9.6 mm Phillips #0.
      • Pulling the trigger will keep spring from launching out of the gun when the two halves are separated.
      Demander à FixBot
    4. Nerf Recon CS-6 Main Spring Replacement, Remove Plunger Cap: étape 4, image 1 de 1
      • Remove the screws on the plunger cap.
      • Tug the plunger cap off.
      Demander à FixBot
    5. Nerf Recon CS-6 Main Spring Replacement, Remove Slide Screws: étape 5, image 1 de 1
      • Remove the 2 screws on the slide.
      • Hold the two halves of the gun together to prevent any springs from launching out.
      Demander à FixBot
    6. Nerf Recon CS-6 Main Spring Replacement, Split the Gun in Half: étape 6, image 1 de 2 Nerf Recon CS-6 Main Spring Replacement, Split the Gun in Half: étape 6, image 2 de 2
      • Pull the gun apart at the middle seam.
      • Watch for any springs that might launch out.
      Demander à FixBot
    1. Nerf Recon CS-6 Main Spring Replacement, Remove Spring: étape 7, image 1 de 2 Nerf Recon CS-6 Main Spring Replacement, Remove Spring: étape 7, image 2 de 2
      • Pull the spring out the back of the gun.
      Demander à FixBot
8 autres ont terminé cette réparation.
Asad Qureshi
Membre depuis le 10/22/14
595 Réputation
3 tutoriels rédigés
Équipe
Baylor, Team 8-14, Williams Fall 2014 Membre de l'équipe Baylor, Team 8-14, Williams Fall 2014
BU-WILLIAMS-F14S8G14
3 membres
6 tutoriels rédigés
1 commentaire de tutoriel
Where can you buy replacement springs from?
Tom Hallam - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 36
Total : 6,593
