Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Nexus 10 Display Replacement
Ce dont vous avez besoin
  1. Nexus 10 Display Replacement, Battery: étape 1, image 1 de 3 Nexus 10 Display Replacement, Battery: étape 1, image 2 de 3 Nexus 10 Display Replacement, Battery: étape 1, image 3 de 3
    • Using a plastic opening tool, remove the thin plastic cover from back of the tablet by prying up from its small tab.
    Demander à FixBot
    Ajouter un commentaire
  2. Nexus 10 Display Replacement: étape 2, image 1 de 1
    • Remove the five 2mm screws on the back of the device using a PH00 screwdriver.
    Demander à FixBot
  3. Nexus 10 Display Replacement: étape 3, image 1 de 3 Nexus 10 Display Replacement: étape 3, image 2 de 3 Nexus 10 Display Replacement: étape 3, image 3 de 3
    • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
    • Pull the the plastic backing off the display assembly using your hands.
    • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
    Demander à FixBot
  4. Nexus 10 Display Replacement: étape 4, image 1 de 3 Nexus 10 Display Replacement: étape 4, image 2 de 3 Nexus 10 Display Replacement: étape 4, image 3 de 3
    • Detach the three connector ribbons passing over the battery using the plastic opening tool.
    Demander à FixBot
  5. Nexus 10 Display Replacement: étape 5, image 1 de 1
    • Remove the twelve 2mm screws around the perimeter of the battery with a PH00 screwdriver.
    Demander à FixBot
  6. Nexus 10 Display Replacement: étape 6, image 1 de 2 Nexus 10 Display Replacement: étape 6, image 2 de 2
    • Disconnect the battery by lifting it upward and pulling it away from the connector.
    Demander à FixBot
  7. Nexus 10 Display Replacement, Headphone Jack: étape 7, image 1 de 1
    • Remove one screw on the logic board with a PH00 screwdriver.
    Demander à FixBot
  8. Nexus 10 Display Replacement: étape 8, image 1 de 3 Nexus 10 Display Replacement: étape 8, image 2 de 3 Nexus 10 Display Replacement: étape 8, image 3 de 3
    • Disconnect right speaker connector ribbon from logic board.
    • Lift the speaker out by pulling up on its corner.
    Demander à FixBot
  9. Nexus 10 Display Replacement: étape 9, image 1 de 3 Nexus 10 Display Replacement: étape 9, image 2 de 3 Nexus 10 Display Replacement: étape 9, image 3 de 3
    • Disconnect connectors around the perimeter of the motherboard.
    Demander à FixBot
  10. Nexus 10 Display Replacement: étape 10, image 1 de 2 Nexus 10 Display Replacement: étape 10, image 2 de 2
    • Remove motherboard by gently pulling upward under its corner.
    Demander à FixBot
  11. Nexus 10 Display Replacement: étape 11, image 1 de 1
    • Remove the three 2mm screws along the right side of the device using a PH00 screwdriver.
    Demander à FixBot
  12. Nexus 10 Display Replacement: étape 12, image 1 de 2 Nexus 10 Display Replacement: étape 12, image 2 de 2
    • Unseat the small vibrator motor by gently applying upward pressure with a spudger.
    Demander à FixBot
  13. Nexus 10 Display Replacement: étape 13, image 1 de 2 Nexus 10 Display Replacement: étape 13, image 2 de 2
    • Lift the assembly by gently applying upward pressure with the spudger on the assembly.
    Demander à FixBot
  14. Nexus 10 Display Replacement: étape 14, image 1 de 2 Nexus 10 Display Replacement: étape 14, image 2 de 2
    • Gently pull battery-audio jack-USB assembly upward, detaching it from its adhesive.
    Demander à FixBot
  15. Nexus 10 Display Replacement, Display: étape 15, image 1 de 2 Nexus 10 Display Replacement, Display: étape 15, image 2 de 2
    • Detach LCD connector ribbon by pressing upward on connector latch using a plastic opening tool.
    Demander à FixBot
  16. Nexus 10 Display Replacement: étape 16, image 1 de 2 Nexus 10 Display Replacement: étape 16, image 2 de 2
    • Unscrew the two 2mm Phillips #00 screws holding the ribbon in place.
    • Remove the board by tilting it forward and pulling outward.
    Demander à FixBot
  17. Nexus 10 Display Replacement: étape 17, image 1 de 1
    • Remove second speaker by gently tilting and pulling upward.
    Demander à FixBot
  18. Nexus 10 Display Replacement: étape 18, image 1 de 3 Nexus 10 Display Replacement: étape 18, image 2 de 3 Nexus 10 Display Replacement: étape 18, image 3 de 3
    • Unscrew the two 2mm screws securing the micro HDMI connector with a #PH00 screwdriver.
    • Remove the connector by liberally applying upward pressure.
    Demander à FixBot
  19. Nexus 10 Display Replacement: étape 19, image 1 de 3 Nexus 10 Display Replacement: étape 19, image 2 de 3 Nexus 10 Display Replacement: étape 19, image 3 de 3
    • Unscrew the 2mm Phillips #00 screw that holds the flash enclosure.
    • Remove the flash assembly with a plastic opening tool by lifting the assembly upward.
    Demander à FixBot
6 autres ont terminé cette réparation.
Benjamin Troller
Membre depuis le 04/11/16
2 239 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 34-18, Maness Spring 2016 Membre de l'équipe Cal Poly, Team 34-18, Maness Spring 2016
CPSU-MANESS-S16S34G18
4 membres
5 tutoriels rédigés
4 commentaires de tutoriel
I’m waiting for the instructions regarding how to remove the old screen and insert the new - it seems to be missing
John Walker - Réponse Partager
It seems you just have to buy a replacement for that whole front housing, including the screen assembly
Oliver Nichol - Réponse Partager
Still waiting to see how the screen is remove
Frank - Réponse Partager
he cambiado la bateria y he partido el presor negro del conector de LCD y no me me funciona, se puede comprar esa pieza negra?
Diego Mera - Réponse Partager
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 11
30 derniers jours : 47
Total : 9,123
