Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Nikon D90 Flash Bulb Replacement
Ce dont vous avez besoin
    1. Nikon D90 Flash Bulb Replacement, Open the Flash: étape 1, image 1 de 3 Nikon D90 Flash Bulb Replacement, Open the Flash: étape 1, image 2 de 3 Nikon D90 Flash Bulb Replacement, Open the Flash: étape 1, image 3 de 3
      • Use a plastic opening tool to lift up the flash.
      Demander à FixBot
      Ajouter un commentaire
    2. Nikon D90 Flash Bulb Replacement, Flash Casing Screws: étape 2, image 1 de 2 Nikon D90 Flash Bulb Replacement, Flash Casing Screws: étape 2, image 2 de 2
      • Using a PH00 screwdriver, remove the two 5.3 mm Phillips screws from the flash casing.
      • Be careful not to strip the screw heads.
      Demander à FixBot
    3. Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: étape 3, image 1 de 3 Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: étape 3, image 2 de 3 Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: étape 3, image 3 de 3
      • Use a plastic opening tool and carefully pry open the top casing of the flash.
      • Then, lift off the top casing of the flash.
      Demander à FixBot
    1. Nikon D90 Flash Bulb Replacement, Removing the Bulb Tape: étape 4, image 1 de 2 Nikon D90 Flash Bulb Replacement, Removing the Bulb Tape: étape 4, image 2 de 2
      Outil utilisé dans cette étape :
      • Carefully unclip the bulb casing from the plastic casing using tweezers.
      • Remove the black and white tape on the bulb casing.
      • This tape is what holds the wires and bulb in place.
      Demander à FixBot
    2. Nikon D90 Flash Bulb Replacement, Removing the Bulb: étape 5, image 1 de 3 Nikon D90 Flash Bulb Replacement, Removing the Bulb: étape 5, image 2 de 3 Nikon D90 Flash Bulb Replacement, Removing the Bulb: étape 5, image 3 de 3
      • Remove the rubber stopper on the left and right side of the bulb.
      • Separate the rubber stopper from the white and black tape.
      • The bulb can now be slid out and replaced.
      • Be careful not to break the bulb or cut yourself on the broken bulb.
      Demander à FixBot
8 autres ont terminé cette réparation.
jonothon cawley
Membre depuis le 10/20/14
354 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-7, Duarte Fall 2014 Membre de l'équipe UMass Dartmouth, Team 1-7, Duarte Fall 2014
UMASSD-DUARTE-F14S1G7
3 membres
6 tutoriels rédigés
2 commentaires de tutoriel
thanks for instruction…………really helpfull
hebi - Réponse Partager
Hi guys do you know where to get this bulb?please help
Martin Mitter - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 18
30 derniers jours : 52
Total : 8,326
