Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Ninja Foodi SP101 Control Panel Replacement
Ce dont vous avez besoin
    1. Ninja Foodi SP101 Control Panel Replacement, Feet: étape 1, image 1 de 2 Ninja Foodi SP101 Control Panel Replacement, Feet: étape 1, image 2 de 2
      • Use a TR10 screwdriver to remove the four 11mm screws holding the black lever bar in place.
      Demander à FixBot
      Ajouter un commentaire
    2. Ninja Foodi SP101 Control Panel Replacement: étape 2, image 1 de 1
      • Remove the black lever bar.
      Demander à FixBot
    1. Ninja Foodi SP101 Control Panel Replacement, Side Panels: étape 3, image 1 de 1
      • Use a Phillips #1 screwdriver to remove the three 8mm screws on each side of the back panel.
      Demander à FixBot
    2. Ninja Foodi SP101 Control Panel Replacement: étape 4, image 1 de 2 Ninja Foodi SP101 Control Panel Replacement: étape 4, image 2 de 2
      • Flip the device upside down and open the bottom panel.
      • Remove the 3 x philips #2 screws along the top edge of the interior using a screwdriver. The Bottom 2 do not have to be removed.
      Demander à FixBot
    3. Ninja Foodi SP101 Control Panel Replacement: étape 5, image 1 de 3 Ninja Foodi SP101 Control Panel Replacement: étape 5, image 2 de 3 Ninja Foodi SP101 Control Panel Replacement: étape 5, image 3 de 3
      • Remove the control side panel. To remove it, push forward towards then front control panel to release the tabs out of the main body. Fold away the side panel when the tabs have visually released from their slots in the main body.
      Demander à FixBot
    4. Ninja Foodi SP101 Control Panel Replacement: étape 6, image 1 de 2 Ninja Foodi SP101 Control Panel Replacement: étape 6, image 2 de 2
      • Lift the handle and pull the side panel out.
      • Remove the handle side panel.
      Demander à FixBot
    1. Ninja Foodi SP101 Control Panel Replacement, Control Panel: étape 7, image 1 de 1
      • Remove the 10mm screw using the Phillips #1 screwdriver.
      • This screw connects the motherboard to the motor.
      Demander à FixBot
    2. Ninja Foodi SP101 Control Panel Replacement: étape 8, image 1 de 3 Ninja Foodi SP101 Control Panel Replacement: étape 8, image 2 de 3 Ninja Foodi SP101 Control Panel Replacement: étape 8, image 3 de 3
      • Locate the control panel.
      • Slide the top panel outwards and to the right.
      Demander à FixBot
    3. Ninja Foodi SP101 Control Panel Replacement: étape 9, image 1 de 1
      • Remove the three 8 mm screws with the Phillips #1 screwdriver.
      • These are located on the control panel side that was facing inward.
      Demander à FixBot
    4. Ninja Foodi SP101 Control Panel Replacement: étape 10, image 1 de 2 Ninja Foodi SP101 Control Panel Replacement: étape 10, image 2 de 2
      • Unclip the wires from the motherboard.
      Demander à FixBot
    5. Ninja Foodi SP101 Control Panel Replacement: étape 11, image 1 de 1
      • Remove the control panel.
      Demander à FixBot
2 autres ont terminé cette réparation.
Griffin Peterson
Membre depuis le 01/30/24
652 Réputation
6 tutoriels rédigés
Équipe
Utah Tech University, Team 1-4, McMurrin Spring 2024 Membre de l'équipe Utah Tech University, Team 1-4, McMurrin Spring 2024
UTAHTECH-MCMURRIN-S24S1G4
2 membres
18 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 28
30 derniers jours : 145
Total : 3,045
