Introduction
Figure out a way to break your Circle Pad? Luckily, you can replace it with a new one.
Pièces
Insert a plastic opening tool into the notch in the lower case above the battery.
Pry the battery up with the plastic opening tool.
Grab the top edge of the battery and lift it out of the lower case.
Remove the nine 6.3 mm black Phillips screws from the lower case.
Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
Remove the two 7.7 mm Phillips screws securing the back of the Circle Pad to the motherboard.
Remove the two 4.5 mm Phillips screws securing the SD board to the motherboard.
Slide the flat end of a spudger under the corner of the Wi-Fi board, and lift it away from the motherboard.
Grasp the microphone ribbon cable near the microphone with a pair of tweezers.
Pull the microphone straight up out of the upper case.
Use a spudger to orient the Circle Pad and plastic ring so that the slit in the ring is 180o from the opening in the bottom of the Circle Pad.
33 autres ont terminé cette réparation.
30 commentaires
Great guide, just upgraded my joystick. Bought my replacement from shapeways. The replacement is metal so it won't break like the last one. Also it's a lot more comfortable.
Anyway highly recommend this replacement:
yeah where can I buy a new circle pad? mine broke in half the lower half is still inside my 3ds XL and I refuse to pay $135 nintendo non-warranty fee just for this problem.
You can find them on Ebay and Amazon, the ones I found on Amazon were massively overpriced though…
Blyatac -
