Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Nokero SunRay Pro Power Panel USB Assembly Replacement
Ce dont vous avez besoin
    1. Nokero SunRay Pro Power Panel USB Assembly Replacement, Front and Back Case: étape 1, image 1 de 1
      • Turn over the device so that the back of the device is facing up.
      Demander à FixBot
      Ajouter un commentaire
    2. Nokero SunRay Pro Power Panel USB Assembly Replacement: étape 2, image 1 de 3 Nokero SunRay Pro Power Panel USB Assembly Replacement: étape 2, image 2 de 3 Nokero SunRay Pro Power Panel USB Assembly Replacement: étape 2, image 3 de 3
      • Insert the first plastic opening tool along the side to pry open the case.
      • Sliding the plastic opening tool, while inserted, along the seam may help the removal process.
      • Use a second plastic opening tool to help separate the remaining seams.
      Demander à FixBot
    3. Nokero SunRay Pro Power Panel USB Assembly Replacement: étape 3, image 1 de 2 Nokero SunRay Pro Power Panel USB Assembly Replacement: étape 3, image 2 de 2
      • There is a long strip of double sided adhesive foam tape that prevents the back case from easily being removed.
      • Pull the back case off by applying steady pressure to remove it from the adhesive foam tape.
      Demander à FixBot
    4. Nokero SunRay Pro Power Panel USB Assembly Replacement: étape 4, image 1 de 2 Nokero SunRay Pro Power Panel USB Assembly Replacement: étape 4, image 2 de 2
      • Use the Phillips precision screwdriver to unscrew the two 5.0 mm Phillips screws from the circuit board.
      • Remove the solar panel and circuit board from the front case.
      Demander à FixBot
    1. Nokero SunRay Pro Power Panel USB Assembly Replacement, USB Assembly/ Solar Panel: étape 5, image 1 de 2 Nokero SunRay Pro Power Panel USB Assembly Replacement, USB Assembly/ Solar Panel: étape 5, image 2 de 2
      • Solder the two contact points identified by the "S+" and "S-" to disconnect the USB assembly.
      Demander à FixBot
Nicholas Orr
Membre depuis le 01/20/15
229 Réputation
2 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 38
Total : 556
