Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Nokia 6086 Screen Replacement
Ce dont vous avez besoin
  1. Nokia 6086 Screen Replacement, Battery: étape 1, image 1 de 1
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
    Demander à FixBot
    Ajouter un commentaire
  2. Nokia 6086 Screen Replacement: étape 2, image 1 de 3 Nokia 6086 Screen Replacement: étape 2, image 2 de 3 Nokia 6086 Screen Replacement: étape 2, image 3 de 3
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    Demander à FixBot
  3. Nokia 6086 Screen Replacement: étape 3, image 1 de 3 Nokia 6086 Screen Replacement: étape 3, image 2 de 3 Nokia 6086 Screen Replacement: étape 3, image 3 de 3
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
    Demander à FixBot
  4. Nokia 6086 Screen Replacement, Top Front Cover: étape 4, image 1 de 1
    • Close the phone.
    • Face the front cover forward.
    Demander à FixBot
  5. Nokia 6086 Screen Replacement: étape 5, image 1 de 2 Nokia 6086 Screen Replacement: étape 5, image 2 de 2
    • Locate the 4.5 mm notch at the top of the phone.
    • Place the iPod opening tool into the opening.
    • Slightly prop up the top section by lifting the tool.
    Demander à FixBot
  6. Nokia 6086 Screen Replacement: étape 6, image 1 de 3 Nokia 6086 Screen Replacement: étape 6, image 2 de 3 Nokia 6086 Screen Replacement: étape 6, image 3 de 3
    • Wedge the iPod opening tool between the top cover and the phone.
    • Gently lift the top cover away from the phone using the iPod opening tool.
    • This unlatches each hook that connects the top cover to the phone.
    • Repeat for both the left and the right sides of the phone.
    • Place the top cover aside once the top cover is completely disconnected from the phone.
    Demander à FixBot
  7. Nokia 6086 Screen Replacement, Screen: étape 7, image 1 de 3 Nokia 6086 Screen Replacement, Screen: étape 7, image 2 de 3 Nokia 6086 Screen Replacement, Screen: étape 7, image 3 de 3
    • Locate the four screws on the phone.
    • The top right screw is located under the black connector piece.
    • To remove the connector piece gently lift it off of its connector.
    • Take the T6 driver and remove the screws.
    Demander à FixBot
  8. Nokia 6086 Screen Replacement: étape 8, image 1 de 1
    • Carefully lift up the motherboard.
    Demander à FixBot
  9. Nokia 6086 Screen Replacement: étape 9, image 1 de 2 Nokia 6086 Screen Replacement: étape 9, image 2 de 2
    • Find the orange slip on the motherboard.
    • Peel back the orange slip to expose the screen.
    Demander à FixBot
  10. Nokia 6086 Screen Replacement: étape 10, image 1 de 3 Nokia 6086 Screen Replacement: étape 10, image 2 de 3 Nokia 6086 Screen Replacement: étape 10, image 3 de 3
    • Place the ipod opening tool under the screen.
    • Remove the damaged screen with the ipod opening tool.
    Demander à FixBot
Caitlin Rahm
Membre depuis le 04/15/10
78 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 26-30, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 26-30, Regan Spring 2010
CPSU-REGAN-S10S26G30
4 membres
36 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 33
Total : 3,856
