Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Nokia N900 Camera Replacement
Ce dont vous avez besoin
  1. Nokia N900 Camera Replacement, Camera: étape 1, image 1 de 1
    • Turn the phone around to the back. Sometimes the phone's back camera slider will not work. If this situation comes about replace your back cover.
    Demander à FixBot
    Ajouter un commentaire
  2. Nokia N900 Camera Replacement: étape 2, image 1 de 1
    • In the case that you do need a new back cover remove it by locating the slit on the side of the phone allowing you to take off the cover, but if you need to further get to your camera you will need to remove the back cover as well.
    Demander à FixBot
  3. Nokia N900 Camera Replacement: étape 3, image 1 de 1
    • Remove the battery
    Demander à FixBot
  4. Nokia N900 Camera Replacement: étape 4, image 1 de 1
    • Now that we have taken everything off the back of the phone we will need to take a screw driver and take the six screw located on the back out of the phone. This will allow you to take apart the phone in two halves.
    • Camera
    Demander à FixBot
  5. Nokia N900 Camera Replacement: étape 5, image 1 de 1
    • You can use the blue plastic opening tool to remove the motherboard from the back of the phone.
    • The camera is located on the back of the motherboard.
    Demander à FixBot
  6. Nokia N900 Camera Replacement: étape 6, image 1 de 1
    • Your phone should now be able to separate into two pieces. One side being the back of the phone where the camera is located and the other being the side with the touch screen.
    • Back side of the phone where the camera is located
    Demander à FixBot
  7. Nokia N900 Camera Replacement: étape 7, image 1 de 1
    • Here are the two main pieces of the camera.
    Demander à FixBot
  8. Nokia N900 Camera Replacement: étape 8, image 1 de 1
    • The camera can be popped out easily using a blunt knife or credit card. A new camera unit can be put into the same place. In case a Nokia N900 camera unit cannot be found, it is possible to use a Nokia N79 camera without causing damage.
    Demander à FixBot
Juan Haro
Membre depuis le 03/13/14
284 Réputation
2 tutoriels rédigés
Équipe
New Mexico State, Team 1-4, Easley Spring 2014 Membre de l'équipe New Mexico State, Team 1-4, Easley Spring 2014
NMSU-EASLEY-S14S1G4
4 membres
4 tutoriels rédigés
1 commentaire de tutoriel
Where to find a camera part ?
Thanks
François Soltic - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 36
Total : 1,555
