Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Numark N4 Effect button cover Replacement
Ce dont vous avez besoin
  1. Numark N4 Effect button cover Replacement, Numark N4 Disassembly: étape 1, image 1 de 1
    • Turn the Numark N4 over so that the bottom panel is facing upwards.
    • Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
    Demander à FixBot
    Ajouter un commentaire
  2. Numark N4 Effect button cover Replacement: étape 2, image 1 de 1
    • Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
    Demander à FixBot
  3. Numark N4 Effect button cover Replacement: étape 3, image 1 de 1
    • Using your fingers, gently unplug the larger ribbon cable as pictured.
    Demander à FixBot
  4. Numark N4 Effect button cover Replacement: étape 4, image 1 de 1
    • Using your fingers, gently unplug the smaller ribbon cable as pictured.
    Demander à FixBot
  5. Numark N4 Effect button cover Replacement: étape 5, image 1 de 1
    • Using your fingers, gently unplug the yellow and red cable as pictured.
    Demander à FixBot
  6. Numark N4 Effect button cover Replacement: étape 6, image 1 de 1
    • Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
    Demander à FixBot
  7. Numark N4 Effect button cover Replacement, Effect button cover: étape 7, image 1 de 1
    • Locate the top right PCB circuit board.
    Demander à FixBot
  8. Numark N4 Effect button cover Replacement: étape 8, image 1 de 1
    • Unplug the two ribbon cables as shown.
    Demander à FixBot
  9. Numark N4 Effect button cover Replacement: étape 9, image 1 de 1
    • Loosen and remove the 11 12mm screws from the circuit board using Phillips #2 screwdriver.
    Demander à FixBot
  10. Numark N4 Effect button cover Replacement: étape 10, image 1 de 1
    • Carefully remove the circuit board from its housing.
    Demander à FixBot
  11. Numark N4 Effect button cover Replacement: étape 11, image 1 de 1
    • Carefully remove the plastic button covers as depicted.
    Demander à FixBot
3 autres ont terminé cette réparation.
Erik Charlton
Membre depuis le 10/10/17
900 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S13-G11, Cagle Fall 2017 Membre de l'équipe USF Tampa, Team S13-G11, Cagle Fall 2017
USFT-CAGLE-F17S13G11
4 membres
12 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 6
30 derniers jours : 32
Total : 806
