Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Numark N4 USB Port Replacement
Ce dont vous avez besoin
    1. Numark N4 USB Port Replacement, Numark N4 Disassembly: étape 1, image 1 de 1
      • Turn the Numark N4 over so that the bottom panel is facing upwards.
      • Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
      Demander à FixBot
      Ajouter un commentaire
    2. Numark N4 USB Port Replacement: étape 2, image 1 de 1
      • Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
      Demander à FixBot
    3. Numark N4 USB Port Replacement: étape 3, image 1 de 1
      • Using your fingers, gently unplug the larger ribbon cable as pictured.
      Demander à FixBot
    4. Numark N4 USB Port Replacement: étape 4, image 1 de 1
      • Using your fingers, gently unplug the smaller ribbon cable as pictured.
      Demander à FixBot
    5. Numark N4 USB Port Replacement: étape 5, image 1 de 1
      • Using your fingers, gently unplug the yellow and red cable as pictured.
      Demander à FixBot
    6. Numark N4 USB Port Replacement: étape 6, image 1 de 1
      • Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
      Demander à FixBot
    1. Numark N4 USB Port Replacement, USB Port: étape 7, image 1 de 1
      • Loosen and remove the five 12mm screws from the circuit board using a Phillips #2 screwdriver.
      Demander à FixBot
    2. Numark N4 USB Port Replacement: étape 8, image 1 de 1
      • Carefully remove the circuit board from its housing.
      Demander à FixBot
    3. Numark N4 USB Port Replacement: étape 9, image 1 de 1
      • Locate the USB on the circuit board.
      • Using a soldering station, carefully desolder the connection points to the USB outlet.
      • To review soldering safety and techniques, please visit Comment souder et dessouder des connexions.
      Demander à FixBot
4 autres ont terminé cette réparation.
Erik Charlton
Membre depuis le 10/10/17
900 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S13-G11, Cagle Fall 2017 Membre de l'équipe USF Tampa, Team S13-G11, Cagle Fall 2017
USFT-CAGLE-F17S13G11
4 membres
12 tutoriels rédigés
1 commentaire de tutoriel
i we like to get the new board of dis numark n4
daniel benson - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 44
Total : 3,067
