Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Oculus Rift DK1 Control Box Buttons Replacement
Ce dont vous avez besoin
  1. Oculus Rift DK1 Control Box Buttons Replacement, Control Box Bottom Cover: étape 1, image 1 de 3 Oculus Rift DK1 Control Box Buttons Replacement, Control Box Bottom Cover: étape 1, image 2 de 3 Oculus Rift DK1 Control Box Buttons Replacement, Control Box Bottom Cover: étape 1, image 3 de 3
    • Use a plastic opening tool to carefully pry off the four rubber feet from the control box.
    • You have now revealed the four 9 mm Phillips #1 screws underneath the rubber feet.
    Demander à FixBot
    Ajouter un commentaire
  2. Oculus Rift DK1 Control Box Buttons Replacement: étape 2, image 1 de 3 Oculus Rift DK1 Control Box Buttons Replacement: étape 2, image 2 de 3 Oculus Rift DK1 Control Box Buttons Replacement: étape 2, image 3 de 3
    • Use a Phillips #1 Screwdriver to unscrew the four 9mm Phillips screws on the bottom of the control box.
    • You can now remove the bottom lid of the control box. It should come apart easily.
    Demander à FixBot
  3. Oculus Rift DK1 Control Box Buttons Replacement, Control Box  Motherboard: étape 3, image 1 de 3 Oculus Rift DK1 Control Box Buttons Replacement, Control Box  Motherboard: étape 3, image 2 de 3 Oculus Rift DK1 Control Box Buttons Replacement, Control Box  Motherboard: étape 3, image 3 de 3
    • Use your finger(s) to start lifting the motherboard from the control box casing. While doing so, use your other hand to push the DVI connector into the control box casing.
    • When the DVI connector has cleared the casing, lift the motherboard.
    • Be careful! There should be two sets of wires still connected to the control box - do not tug on them. Simply flip the motherboard over to access these wires.
    • When reassembling the device, ensure that all of the wires are clear of the buttons.
    Demander à FixBot
  4. Oculus Rift DK1 Control Box Buttons Replacement: étape 4, image 1 de 3 Oculus Rift DK1 Control Box Buttons Replacement: étape 4, image 2 de 3 Oculus Rift DK1 Control Box Buttons Replacement: étape 4, image 3 de 3
    • Use a plastic opening tool or your fingernails to disconnect the grey wire connectors. To make removal easier, pry the left and right edges to carefully remove the connector.
    • Do so for both of the wires attached to the motherboard.
    • Now fully separate the motherboard from the control box casing.
    Demander à FixBot
  5. Oculus Rift DK1 Control Box Buttons Replacement, Control Box Buttons: étape 5, image 1 de 1
    • You now have the motherboard separated from the control box.
    • Identify the buttons that are not working.
    Demander à FixBot
  6. Oculus Rift DK1 Control Box Buttons Replacement, Desoldering Button: étape 6, image 1 de 1
    • For each button that needs to be replaced, use a soldering iron and soldering braid to desolder the four metal points.
    • Be careful! Soldering iron is hot.
    Demander à FixBot
  7. Oculus Rift DK1 Control Box Buttons Replacement, Removing Button: étape 7, image 1 de 2 Oculus Rift DK1 Control Box Buttons Replacement, Removing Button: étape 7, image 2 de 2
    Outil utilisé dans cette étape :
    • Now that each button with issues is desoldered, use tweezers to grab each button and detach from the motherboard.
    • If the button does not come off easily, go back to the previous step and ensure each of the four metal points are properly desoldered.
    Demander à FixBot
Ross De Vito
Membre depuis le 01/13/15
246 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 70-5, Forte Winter 2015 Membre de l'équipe Cal Poly, Team 70-5, Forte Winter 2015
CPSU-FORTE-W15S70G5
4 membres
12 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 25
Total : 970
