Introduction
Follow this guide to remove and replace a defective earpiece speaker for the OnePlus 3. This requires removing the motherboard in order to access the earpiece. The hardest part of the guide is getting the frame clips free.
Some guide images will show the battery already removed from the phone. You do not need to remove the battery for the earpiece speaker procedure.
Ce dont vous avez besoin
Insert a SIM eject tool, bit, or straightened paperclip into the hole located between the SIM card slot and the power button.
Press firmly to eject the SIM card tray.
Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
Frame seam: This is where the plastic frame meets the back cover. It is recessed into the back cover. Only pry at this seam.
There are fourteen clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
Lift the screen up and remove it.
Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
Squeeze along the long edges of the phone to snap the remaining clips into place.
Use the point of a spudger to pry up and disconnect the battery connector from its socket, located above the top right corner of the battery pack.
Bend the connector away from the socket to prevent accidental contact.
Remove the 3 mm Phillips screw securing the cable bracket.
Remove the cable bracket.
Slide the point of a spudger underneath the antenna interconnect cable located at the bottom left corner of the motherboard.
Pry up and disconnect the antenna interconnect cable.
Squeeze the tweezer tips together and insert the point under one of the earpiece speaker clips.
Pull the tweezer point up slowly to pry the earpiece speaker out of its recess.
Repair didn’t go as planned? Check out our OnePlus 3 Answers community for troubleshooting help.
9 autres ont terminé cette réparation.
3 commentaires
Had a bunch of crap / dirt between the outer grid (visible from the front) and the fine piece of cloth. Cleaned it, but this was the reason why I couldn’t hear.
Thank you! Very detailed!
Thank you ! Super detailed and very nice pictures !
Vorsicht an alle Nachahmer: Mein Display ist einfach mehrfach gerissen, während ich versucht habe, es zu lösen. Keine Chance. Das war so fest verankert, dass ich mit keinem der Werkzeuge richtig was erreichen konnte. Dabei wollte ich nur mal die Ohrmuschel reinigen :-(
