Aller au contenu principal
OnePlus Nord N20 5G Battery Replacement
Ce dont vous avez besoin
  1. OnePlus Nord N20 5G Battery Replacement, Back Cover: étape 1, image 1 de 1
    • Insert the SIM ejection tool or a spudger in the small hole next to the SIM tray.
    • Push it gently until the tray pops out.
    • Remove the SIM card tray by sliding it outwards.
  2. OnePlus Nord N20 5G Battery Replacement: étape 2, image 1 de 2 OnePlus Nord N20 5G Battery Replacement: étape 2, image 2 de 2
    • Heat the iOpener in a microwave for about 30 seconds. If the iOpener isn’t hot enough, reheat it for another 10-30 seconds.
    • Apply the heated iOpener on the backside of the phone for a minute to loosen the adhesive.
    • Use the iFixit opening tool and slide it along the edges of the phone to pry the back panel off.
  3. OnePlus Nord N20 5G Battery Replacement, Battery: étape 3, image 1 de 3 OnePlus Nord N20 5G Battery Replacement, Battery: étape 3, image 2 de 3 OnePlus Nord N20 5G Battery Replacement, Battery: étape 3, image 3 de 3
    • Remove the 18 3.9 mm screws using a Phillips #0 screwdriver.
  4. OnePlus Nord N20 5G Battery Replacement: étape 4, image 1 de 2 OnePlus Nord N20 5G Battery Replacement: étape 4, image 2 de 2
    • Take the iFixit opening tool and run it along the edges of the frame.
    • Separate the back housing from the frame of the screen.
  5. OnePlus Nord N20 5G Battery Replacement: étape 5, image 1 de 2 OnePlus Nord N20 5G Battery Replacement: étape 5, image 2 de 2
    • Disconnect the brackets attached to the motherboard with the help of a spudger.
  6. OnePlus Nord N20 5G Battery Replacement: étape 6, image 1 de 2 OnePlus Nord N20 5G Battery Replacement: étape 6, image 2 de 2
    • Remove the tape that's covering the battery.
    • Pull up the battery using the green tape on the right side of the battery.
    • Now you can replace the old battery with your new one.
Vedansh Joshi
Membre depuis le 09/26/24
202 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 41
Total : 215
