Introduction
If you're experiencing issues with your motherboard, use this guide to replace it. Be careful not to damage any connectors or wires in the process of opening up your phone.
Ce dont vous avez besoin
Remove the SIM tray.
Using a plastic opening tool, carefully separate the back panel from the main body assembly of the phone. Be extra careful around the SIM slot or other weak areas.
You may encounter some resistance due to hidden locking clips around the inside edge of the phone. Not to worry; just move in one consistent direction around the phone as opposed to jumping from spot to spot!
Top to bottom, left to right, clockwise or counter clockwise, once we make it about half way around the device, the panel is easily removable by hand.
After we have removed the motherboard cover, we notice that the battery is intact and has a black ribbon attached to it, which is mounted on the logic board.
Using the spudger, carefully begin to lift the the battery up from the side opposite the ribbon. Be aware that there is high-grade adhesive holding the battery in its bay, so proceed with caution.
2 autres ont terminé cette réparation.
2 commentaires
Your post is very meticulous and impressive for me, I hope to get more good posts. powerline io
I do have an extra metal sheet on top of the motherboard covering the chipsets like a heatsink. How did you remove that?
