Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Optoma HD20 Color Wheel Replacement
Ce dont vous avez besoin
    1. Optoma HD20 Color Wheel Replacement, Disassembling Optoma HD20 Cover: étape 1, image 1 de 2 Optoma HD20 Color Wheel Replacement, Disassembling Optoma HD20 Cover: étape 1, image 2 de 2
      • Twist the focal cap clockwise until it is fully extended.
      • Remove the focal cap by pulling it straight out.
      Demander à FixBot
      Ajouter un commentaire
    2. Optoma HD20 Color Wheel Replacement: étape 2, image 1 de 1
      • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
      Demander à FixBot
    3. Optoma HD20 Color Wheel Replacement: étape 3, image 1 de 1
      • Use a plastic opening tool to gently pry the top cover off of the device.
      • It is easier to pry off the cover from the back side just above the HDMI ports.
      Demander à FixBot
    4. Optoma HD20 Color Wheel Replacement: étape 4, image 1 de 1
      • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
      • Remove the ribbon by disconnecting it from the main circuit board.
      • Lift up the clip holding it down and pull the ribbon out.
      Demander à FixBot
    1. Optoma HD20 Color Wheel Replacement, Color Wheel: étape 5, image 1 de 1
      • Use the plastic opening tool to remove the wiring.
      Demander à FixBot
    2. Optoma HD20 Color Wheel Replacement: étape 6, image 1 de 1
      • Use a Phillips #1 screwdriver to remove the 5.5 mm screws around the pin wheel.
      Demander à FixBot
    3. Optoma HD20 Color Wheel Replacement: étape 7, image 1 de 1
      • Use a Phillips #1 screwdriver to remove 1 more 5.5 mm screw.
      Demander à FixBot
    4. Optoma HD20 Color Wheel Replacement: étape 8, image 1 de 1
      • Using a flat head screw driver unscrew the back part to release the color wheel.
      • Do this carefully because these screws do not pull out.
      Demander à FixBot
    5. Optoma HD20 Color Wheel Replacement: étape 9, image 1 de 1
      • Once unscrewed, remove the color wheel, and replace the part.
      Demander à FixBot
6 autres ont terminé cette réparation.
Trever
Membre depuis le 01/22/15
1 282 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 21-23, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 membres
13 tutoriels rédigés
3 commentaires de tutoriel
I've seen 5 guides say that the lens adjustment cover just pulls straight out, but even with significant force, it doesn't budge. Are there two different versions of the HD20 with two different designs for the cover?
srbaucom - Réponse Partager
I couldn't get the shroud off until I had the plastic top of the projector mostly off.
dlwalter - Réponse Partager
The shroud has clips on it that attach to some bolts coming off the lense so yeah, it will take some force to pop the clips.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 14
30 derniers jours : 46
Total : 9,901
