Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Optoma HD72 Color Wheel Replacement
Ce dont vous avez besoin
    1. Optoma HD72 Color Wheel Replacement, Upper Case: étape 1, image 1 de 2 Optoma HD72 Color Wheel Replacement, Upper Case: étape 1, image 2 de 2
      • Use a Phillips screwdriver to remove the five 2 mm screws on the underside of the device.
      Demander à FixBot
      Ajouter un commentaire
    2. Optoma HD72 Color Wheel Replacement: étape 2, image 1 de 1
      • Flip the device over and slightly lift the upper case, with care not to strain the two cables.
      • Disconnect the two cables that connect the top case to the motherboard.
      • Lift the upper case up and off.
      Demander à FixBot
    1. Optoma HD72 Color Wheel Replacement, Motherboard: étape 3, image 1 de 3 Optoma HD72 Color Wheel Replacement, Motherboard: étape 3, image 2 de 3 Optoma HD72 Color Wheel Replacement, Motherboard: étape 3, image 3 de 3
      • Disconnect all of the cables that are connected to the motherboard.
      Demander à FixBot
    2. Optoma HD72 Color Wheel Replacement: étape 4, image 1 de 1
      • Remove the four 2 mm Phillips screws that secure the motherboard.
      • Lift the motherboard up and out of the chassis.
      Demander à FixBot
    1. Optoma HD72 Color Wheel Replacement, Color Wheel: étape 5, image 1 de 3 Optoma HD72 Color Wheel Replacement, Color Wheel: étape 5, image 2 de 3 Optoma HD72 Color Wheel Replacement, Color Wheel: étape 5, image 3 de 3
      • Remove the three 2 mm Phillips screws that secure the black housing.
      • Lift the black housing off.
      Demander à FixBot
    2. Optoma HD72 Color Wheel Replacement: étape 6, image 1 de 2 Optoma HD72 Color Wheel Replacement: étape 6, image 2 de 2
      • Remove the single 2 mm Phillips screw that secures the color wheel.
      • Lift the color wheel up and out of its housing.
      Demander à FixBot
    3. Optoma HD72 Color Wheel Replacement: étape 7, image 1 de 3 Optoma HD72 Color Wheel Replacement: étape 7, image 2 de 3 Optoma HD72 Color Wheel Replacement: étape 7, image 3 de 3
      • Remove the single 2 mm Phillips screw that secures the circuit board to the side of the color wheel.
      • Use a sharp tool to cut the zip tie that secures the color wheel’s cables.
      • Remove the color wheel.
      Demander à FixBot
Oscar Garcia
Membre depuis le 02/07/24
677 Réputation
5 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 30
Total : 421
