Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Optoma HD72 Projection Lamp Replacement
Ce dont vous avez besoin
  1. Optoma HD72 Projection Lamp Replacement, Projection Lamp: étape 1, image 1 de 1
    • Use a Phillips screwdriver to loosen the single captive 2 mm screw that secures the small lamp panel on the lower case.
    • Remove the panel.
    Demander à FixBot
    Ajouter un commentaire
  2. Optoma HD72 Projection Lamp Replacement: étape 2, image 1 de 1
    • Use a Phillips screwdriver to loosen the two 2 mm screws on the bottom of the projection lamp housing.
    Demander à FixBot
  3. Optoma HD72 Projection Lamp Replacement: étape 3, image 1 de 2 Optoma HD72 Projection Lamp Replacement: étape 3, image 2 de 2
    • Lift the panel off of the device using the metal handle.
    • Disconnect the pink wires from the black plastic housing.
    Demander à FixBot
  4. Optoma HD72 Projection Lamp Replacement: étape 4, image 1 de 3 Optoma HD72 Projection Lamp Replacement: étape 4, image 2 de 3 Optoma HD72 Projection Lamp Replacement: étape 4, image 3 de 3
    • Use a Phillips #2 screwdriver to remove the four 2 mm screws that secure the lamp to its housing.
    • Remove the projection lamp casing by gently lifting the bulb from its housing.
    Demander à FixBot
  5. Optoma HD72 Projection Lamp Replacement: étape 5, image 1 de 2 Optoma HD72 Projection Lamp Replacement: étape 5, image 2 de 2
    • Once the bulb is out, replace it with another bulb and re-secure the housings in reverse order to this guide.
    • The second photo is what the completed bulb housing should look like.
    Demander à FixBot
Oscar Garcia
Membre depuis le 02/07/24
677 Réputation
5 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 8
30 derniers jours : 39
Total : 285
