Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Oster 3905 Lever Spring Replacement
Ce dont vous avez besoin
  1. Oster 3905 Lever Spring Replacement, Slot Levers: étape 1, image 1 de 1
    • Firmly grip your hand around the slot lever.
    Demander à FixBot
    Ajouter un commentaire
  2. Oster 3905 Lever Spring Replacement: étape 2, image 1 de 1
    • Stabilize the toaster by placing your hand on top.
    Demander à FixBot
  3. Oster 3905 Lever Spring Replacement: étape 3, image 1 de 2 Oster 3905 Lever Spring Replacement: étape 3, image 2 de 2
    • Forcefully pull the slot lever away from the toaster by keeping parallel to the table.
    Demander à FixBot
  4. Oster 3905 Lever Spring Replacement: étape 4, image 1 de 1
    • Both slot levers can be removed.
    Demander à FixBot
  5. Oster 3905 Lever Spring Replacement, Outer Shell: étape 5, image 1 de 1
    • Place the toaster upside down so the bottom is facing the ceiling.
    Demander à FixBot
  6. Oster 3905 Lever Spring Replacement: étape 6, image 1 de 2 Oster 3905 Lever Spring Replacement: étape 6, image 2 de 2
    • Take off both rubber feet using a small metal spudger.
    • Wedge a spudger under the feet and pull up to pop off.
    Demander à FixBot
  7. Oster 3905 Lever Spring Replacement: étape 7, image 1 de 1
    • Use a PH#2 screw bit to remove eight 12mm screws that are located around the perimeter.
    • There are two screws under the rubber feet.
    Demander à FixBot
  8. Oster 3905 Lever Spring Replacement: étape 8, image 1 de 1
    • Place the toaster right side up.
    Demander à FixBot
  9. Oster 3905 Lever Spring Replacement: étape 9, image 1 de 2 Oster 3905 Lever Spring Replacement: étape 9, image 2 de 2
    • Grab the outer shell firmly and pull up towards the face of the toaster.
    Demander à FixBot
  10. Oster 3905 Lever Spring Replacement: étape 10, image 1 de 1
    • For this part, you might need to wiggle the toaster to get the outer shell off.
    • The shell will not completely come off until the motherboard is removed in the next step.
    Demander à FixBot
  11. Oster 3905 Lever Spring Replacement: étape 11, image 1 de 3 Oster 3905 Lever Spring Replacement: étape 11, image 2 de 3 Oster 3905 Lever Spring Replacement: étape 11, image 3 de 3
    • Use a J1 screw bit to unscrew eight 8mm screws from the motherboard.
    Demander à FixBot
  12. Oster 3905 Lever Spring Replacement: étape 12, image 1 de 2 Oster 3905 Lever Spring Replacement: étape 12, image 2 de 2
    • Take out the grey “cancel” and “bagel” buttons from the shell.
    Demander à FixBot
  13. Oster 3905 Lever Spring Replacement, Lever Spring: étape 13, image 1 de 2 Oster 3905 Lever Spring Replacement, Lever Spring: étape 13, image 2 de 2
    • Use the plastic opening tool to remove the top metal panel by prying the 4 top metal tabs upwards. They will be able to slide through the openings and be pulled upwards.
    Demander à FixBot
  14. Oster 3905 Lever Spring Replacement: étape 14, image 1 de 2 Oster 3905 Lever Spring Replacement: étape 14, image 2 de 2
    • Once the top metal panel is unhooked, lift and let it hang off the side of the toaster.
    Demander à FixBot
  15. Oster 3905 Lever Spring Replacement: étape 15, image 1 de 3 Oster 3905 Lever Spring Replacement: étape 15, image 2 de 3 Oster 3905 Lever Spring Replacement: étape 15, image 3 de 3
    • Use a metal spudger to pry the 8 tabs upwards along the metal that separates the two slots.
    • Pull the metal spacer upwards to release from the toaster.
    Demander à FixBot
  16. Oster 3905 Lever Spring Replacement: étape 16, image 1 de 2 Oster 3905 Lever Spring Replacement: étape 16, image 2 de 2
    • Remove the spring wrapped around a metal rod at the front of the toaster, located behind the white plastic lever holder.
    Demander à FixBot
Sydney Alcaraz
Membre depuis le 09/12/16
601 Réputation
3 tutoriels rédigés
Équipe
CSU Fullerton, Team 2-1, Bruce Fall 2016 Membre de l'équipe CSU Fullerton, Team 2-1, Bruce Fall 2016
CSUF-BRUCE-F16S2G1
5 membres
12 tutoriels rédigés
2 commentaires de tutoriel
Where's the fix?
D Unger - Réponse Partager
Yeah. You just remove the spring? And then what? Surely removing the spring is not the fix.
kryshu - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 29
Total : 3,452
